Author Topic: Boo Boo Bin  (Read 2922 times)
Boo Boo Bin
« on: November 12, 2018, 09:04:55 AM »
I thought that it might be useful to start a Boo Boo Bin thread where we can all show that we are mortal and make mistakes. So it is only fair I thought I would start with a couple of my features that didn't make it into the final engine  :embarassed:
How many of you remember my numerous attempts at making the crankshafts for my Stuart Triples  ::)
Not so spectacular (or scary when they failed ) But the second photo shows undersized collets, heads where I got the measurements wrong, rotary valves were I put the pin in the wrong position. A bent con rod and piston where I forgot to take it out when I thought the crankshaft was stuck in a crank case and tapped it with a mallet :facepalm:
And my famous Stentor piston with the baffle 90 degrees out. :ShakeHead:
Is anyone else brave enough to be honest  ;)
Re: Boo Boo Bin
« Reply #1 on: November 12, 2018, 09:57:29 AM »
Hello Jo,
You are very, very brave and honest. I wish that I could contribute some photos to this thread...... :mischief:. Don't get me wrong, I have made my share of Boo Boos, it's just I do not take any photos and do not want to be reminded  :lolb:
Offline gerritv
  • St Catharines, ON
    • Gerrit's Hobbies
Re: Boo Boo Bin
« Reply #2 on: November 12, 2018, 12:08:07 PM »
This one from March 2017 when I was building my Eureka Relieving device. I took the description from ME seriously and carved this from solid. A lot of cutting/swarf resulted, one of my first serious jobs on this lathe. Everything seemed fine except that I got one of the eccentrics offside :-(
The part looks great on my wife's desk as a paper weight!
(I made the replacement in 3 parts, a lot less cutting and lower risk of things going wrong.)
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: Boo Boo Bin
« Reply #3 on: November 12, 2018, 02:18:03 PM »
I guess a lot of us have at some point made one of these bent conrods.  ::)
In my case a deep cut caused it to ride over the tool, one for the boo boo bin  :Lol:
Offline gerritv
  • St Catharines, ON
    • Gerrit's Hobbies
Re: Boo Boo Bin
« Reply #4 on: November 12, 2018, 02:51:49 PM »
If that con-rod bend is from your tapping I would hate to be around when you seriously whack something with a hammer :-)
Gerrit
Re: Boo Boo Bin
« Reply #5 on: November 12, 2018, 02:57:30 PM »
If I post all my boo-boos...we'd be out of server space.
But here's my latest...
Two cylinder blocks that got slung out of the vise.
One cylinder block with the cylinder in the wrong place.
One con-rod with too much taken off one end.
Online Jim Nic
  • Buckingham, UK
Re: Boo Boo Bin
« Reply #6 on: November 12, 2018, 03:25:04 PM »
Peter, you're right.
I also have other "trial pieces", too numerous to mention, that end up being flung in the scrap bin usually without pausing to take a picture.  I do sometimes publicise my errors but generally they are a result of my own stupidity and I feel that others would not learn anything from seeing the results of that.
The picture below shows a mandrel with a centre machined on the end and 2 holes for the rod fixing bolts to fit into and transmit the drive.  The other bit is the reprofiled rod after the thought that "This is going well. I'll take a deeper cut." crossed my mind.
« Last Edit: November 12, 2018, 03:30:21 PM by Jim Nic »
Offline Gas_mantle
  • North Yorks - UK.
Re: Boo Boo Bin
« Reply #7 on: November 12, 2018, 03:58:19 PM »
Jim, that short sentence must account for half of all machining errors. The other fatal one is 'This is taking too long, I can save time by doing it this other way'  ;)
Re: Boo Boo Bin
« Reply #8 on: November 12, 2018, 04:10:13 PM »
Most of my boo-boos occur after thoughts like "Is that right?", "What's that sound?", "Something seems off.", "Huh?",...and I ignore myself.
I still haven't accepted the fact that my inner me is smarter than me.
My inner me needs to be more assertive.
Re: Boo Boo Bin
« Reply #9 on: November 12, 2018, 06:32:51 PM »
This cylinder head went in the bin, along with the first 8 pistons for my 3cc vertical engine  :toilet_claw:
Re: Boo Boo Bin
« Reply #10 on: November 12, 2018, 06:42:51 PM »
Most of my bigger boo boos got hidden in the bilge of rc boats as ballast (and I have a bunch of boats!) or cut down for smaller parts.
Online Vixen
Re: Boo Boo Bin
« Reply #11 on: November 12, 2018, 08:54:01 PM »
What happens when you type in a G00 Rapid Move command instead of a G01 controlled feed rate move?
Re: Boo Boo Bin
« Reply #12 on: November 12, 2018, 09:08:41 PM »
Looks like the make-a-spring command!
Re: Boo Boo Bin
« Reply #13 on: November 12, 2018, 10:58:55 PM »
When I was making the flywheels for the Tiny hit and miss engine which required 6 spokes, I miscalculated the RT rotation. It's 60 degrees, not 72 for six spokes... :facepalm2:. If anyone needs a partial 5 spoke though let me know  ;)
Re: Boo Boo Bin
« Reply #14 on: November 13, 2018, 12:21:38 AM »
Bill, in that state it looks like a logo for the Poo Poo company!   :Lol:
