Author Topic: Easton and Andersom beam engine at Bressingham.  (Read 75524 times)
Re: Easton and Andersom beam engine at Bressingham.
« Reply #345 on: December 25, 2019, 01:18:35 AM »
More pics ...and a merry Xmas and a happy new year....
Willy
« Reply #346 on: December 25, 2019, 07:35:05 AM »
Hi Willy, always pure pleasure to see and follow your hand made fabrication work.
« Reply #347 on: December 25, 2019, 10:05:51 AM »
Watching on as usual Willy....looking for more 2020 postings ...compliments of the Season  :cheers:  Derek
« Last Edit: December 25, 2019, 09:40:23 PM by derekwarner »
Offline scc
  • Lancashire, UK
« Reply #348 on: December 26, 2019, 11:18:17 AM »
Loving  it Willy :cheers: :popcorn:       Terry
« Reply #349 on: December 28, 2019, 01:40:20 AM »
Hi All thanks for the comments and encouragement..... more work on the final parts made to the dimensions to fit properly....there will still be more tidying up tp finish them . the pics with the penny are the 14BA bolts for the cotter adjustment... Also some the discarded parts that were not quite correct... I have read that when Cherry Hill made her models she actually made them 2X model size to make sure everything came together and fitted and worked !!
« Reply #350 on: December 28, 2019, 01:44:48 AM »
Wow, those parts are smaller than I thought, or you got out the really big penny.
 :popcorn: :popcorn: :popcorn:
Offline scc
  • Lancashire, UK
« Reply #351 on: December 28, 2019, 12:11:46 PM »
Hi Willy,    Those pictures make me realise that in my shop I have no idea what SMALL is :praise2:     Best Wishes        Terry
« Reply #352 on: January 04, 2020, 02:54:28 AM »
More work on the motion ..making the Radius rod hangers and fitting the parts to give the necessary clearances. Thanks for the comments and these parts are quite big compared to watch making !!!
Willy
« Reply #353 on: January 07, 2020, 01:56:05 AM »
Not a valid vimeo URL.      the engine has now been tested on compressed air again now the Motion work has been completed and adjusted. I can now make the new parts using the dimensions of the temporary parts.
« Reply #354 on: January 07, 2020, 01:58:59 AM »
Its alive!!  FanSteamTastic!
« Reply #355 on: January 07, 2020, 02:07:08 AM »
Hi Chris,  yup and can't wait to finish it and do a steam run .....Also the Steam cars...can you count how many valves there are ?? and those are just the visible ones !!! I counted almost 30 myself....also the steam pressure is about 600 Lbs and the boiler has 3 layers of high tensile steel wrapped around it !!
Willy
« Reply #356 on: January 07, 2020, 11:32:59 AM »
Always nice to see it run after all the work you have put into it Willy  :ThumbsUp:
Offline scc
  • Lancashire, UK
« Reply #357 on: January 07, 2020, 05:34:32 PM »
Great Job Willy :ThumbsUp: :ThumbsUp:       Terry
Offline MJM460
« Reply #358 on: January 08, 2020, 09:12:44 AM »
Well done Willy.  Great to see it running well after all your detailed work.
I notice that the inner vertical link of the parallel motion has an extra bushing.  Drive for a water pump perhaps?
Looking forward to the next steps.
« Reply #359 on: January 09, 2020, 01:52:53 AM »
Hi ALL ,  Thanks for the comments  and MJM yes there is a rod that operates the boiler feed pump , and still lots of work required...here is a pic of the rod...There is also provision for a lever to operate a condenser if fitted...
willy
« Last Edit: January 09, 2020, 02:00:28 AM by steam guy willy »
