Engines > From Kits/Castings
Gardner 3F
TonyM:
So I am going down the casting route. At least for the cylinder and see how that works out. I am getting the patterns printed this week. Just one question for the casters out there. Is a core necessary other than for saving material. Does it make the casting easier or harder.
steamer:
You should probably core the cylinder bore so you dont have shrinkage defects In the us with iron round core comes in q/8 inch increments. Talk to your foundry.
Jasonb:
It also helps keep the cost down if your foundry charge by weight.
You will need to add some draft angle to the flat surfaces particularly the bottom so that it can be be more easily withdrawn from the sand and the core prints if you decide to core it.
TonyM:
The guy does SLA printing and says the pattern will be extremely hard plastic. Does anyone have experience with this for patterns. Cost is around 75GBP for both halves.
TonyM:
The base drawings are done but the cost of printing is prohibitive. I am getting quotes over 1000GBP for the base. Looks like it will be a wooden pattern or a fabrication. I will have to hone my woodworking skills/
Navigation
[0] Message Index
[*] Previous page
Go to full version
