Author Topic: Pennsylvania A3 Switcher (Kozo)  (Read 342780 times)
« Reply #600 on: February 23, 2020, 01:50:20 AM »
Great job. And as usual, excellent documentation.  :ThumbsUp:
« Reply #601 on: February 23, 2020, 05:06:17 PM »
Lots of really good progress Kim!
The side panels also turned out very nice.
« Reply #602 on: February 24, 2020, 01:23:32 AM »
Thanks Zee and Dave! :D
Offline samc88
« Reply #603 on: February 24, 2020, 05:04:47 PM »
Looking good. Lovely work
Sent from my G3121 using Tapatalk
Offline Firebird
  • East Midlands UK
« Reply #604 on: March 03, 2020, 04:20:32 PM »
 :popcorn: :ThumbsUp:
Still following
Rich
« Reply #605 on: March 08, 2020, 01:08:02 AM »
Thank you for the comments, Sam and Rich!
« Reply #606 on: March 08, 2020, 01:10:20 AM »
I’ve been out of town for a while, thus, no update last week.  But today I got a little shop time and finished up the Dummy Side Plates.
First, I drilled out a few of the embossed rivets in the side plates to make room for #0-80 mounting screws.
After carefully positioning the plate, I marked and drilled a hole to receive the mounting screw, then tapped it 0-80 (as shown in the picture).
Did that that for all of the screw hole in the dummy plates then took some beauty shots:
And this, my friends, completes Chapter 5, "Tank", in Kozo’s book.  Next up will be the Manhole.
See you for the next exciting installment!
« Reply #607 on: March 08, 2020, 02:02:18 AM »
Very nice!!
« Reply #608 on: March 08, 2020, 03:52:15 AM »
... then took some beauty shots: ...
And well worth it.  :ThumbsUp:
I'm anxious for the next 'exciting installment'.  :popcorn: :popcorn:
« Reply #609 on: March 08, 2020, 05:29:52 AM »
Thanks Chris and Zee!
Yes, the next installment will be positively riveting, I'm sure!  :ROFL:
« Reply #610 on: March 08, 2020, 12:38:18 PM »
Hello Kim,
That is a work of art, wonderful craftsmanship on your part  :praise2:
Have a great day,
Offline Flyboy Jim
  • Independence, Oregon
« Reply #611 on: March 08, 2020, 02:42:32 PM »
Outstanding work Kim! :ThumbsUp: You've really gotten the hang of this type of metal work.
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #612 on: March 16, 2020, 03:27:48 PM »
Thank you Thomas and Jim!
Things have gotten quite hectic at work (and home) so I haven't had my usual time to check in on the forum!
« Reply #613 on: March 16, 2020, 03:34:31 PM »
Chapter 6.1 – Mounting Plate, Manhole Plate, and Lug
Chapter 6 covers the Tender Manhole.  This is the assembly that will fit in the big square hole on the top of the tender tank.  When complete, you will be able to open the manhole cover to fill the tender with water or to access the hand pump to pump water into the boiler.  The large rectangle plate that holds the manhole cover is also removable to provide easy access to the inside of the tank.
The first part is the Mounting Plate.  It was cut from 0.040” brass sheet.  And since the first several parts are all from the same material I cut those at the same time.  In this picture, clockwise from the top left is the Mounting Plate (1), the manhole plate (2), the manhole flange (4), and the manhole itself (4) (the last two pieces are part of a single assembly, which is why they both have the same number).  The piece of brass in the lower right will become the mounting lug (3) for the manhole plate (just a scrap from the bin).
The bandsaw leaves rough and not-very-straight edges.  So the first thing I did was to even out the top and bottom edges then mill it to width.
Then holding the plate sideways, I milled the other dimension square, and to the correct length.
Then I marked up the part showing where all the holes go and the large cutout in the middle.  It’s a little hard to see the scribe lines with all the scratches in the blue, but trust me, they are there!
Using the DRO I drilled all the holes to size.
Then I poked a hole in the part to remove and used the scroll saw to cut the large opening.
Now I’ve got two pieces! :)
Cleaned up the inside edge using files.
And here’s the completed part!
I used several clamps to hold the mounting plate in place, then drilled a couple of holes for mounting screws.  You can’t really see it in the picture, but the tank is being supported by a piece of wood clamped in the mill vice.
Then I tapped the few holes I drilled:
And attached the mounting plate on the OUTSIDE of the tank. This is not where it will be in the end, it will be attached to the inside.  But this allowed me to drill the rest of the holes for the mounting screws.
And after tapping the remaining holes, we have attached the mounting plate:
And here it is from the top:
The next step was to file down the mounting screws – they are quite short, but still stick out the top of the tank.
So, I filed them down.  I used some tape to help keep me from scratching up the rest of the tank in the process.
And here it is, after being filed down.
The next step will be the manhole plate that fits in on top of the mounting plate.  I started this by milling it square and to size.
You can see that it fits in the hole! :)
That’s all for today, thanks for stopping by to take a look.
« Last Edit: March 24, 2020, 12:53:38 AM by Kim »
« Reply #614 on: March 16, 2020, 08:49:20 PM »
Nice progress Kim  :ThumbsUp:
The last many pictures of the Tender always has me thinking that you are very close to finish it and start on the Loco ..... But you keep on making more parts for the Tender  :thinking:
