Author Topic: Pennsylvania A3 Switcher (Kozo)  (Read 48405 times)
« Reply #60 on: November 23, 2018, 11:07:19 PM »
 :facepalm:    :facepalm:     :facepalm:     :facepalm:    :facepalm:     :facepalm:
Nope, not a type-o. Wish it was.  I cut them at 10o, though it clearly says 3o.
 :hammerbash:
That kinda blows my last few weeks of work.  And an expensive chunk of 12L14....
  :wallbang:
Well, now the question - do I do-em again?  Or decide that my slightly over-tapered tread on these wheels won't matter a smidge, since this will never be used on a track in any serious way. It's more of a mantle piece for me.
Hmm... how noticeable do you think that will be in a finished model?  Will people be shocked and appalled at the cones I'm using for wheels?  Or will it not even be noticed.  :slap:
 :Doh:
Guess I'll think about that for a bit and do something else for a while...
Kim  :facepalm2:
« Reply #61 on: November 23, 2018, 11:16:25 PM »
Ouch! I hate when very carefully, precisely, doing the wrong thing.   :zap:
One other option, recutting the bevel to 3 degrees, and trimming the flange. How much would it reduce the OD of the wheels? Too much?
« Reply #62 on: November 23, 2018, 11:16:53 PM »
The taper is just to keep the wheels on the track going around a curve, and when on a straight track it won't be noticeable.  I wouldn't scrap them.  You can recut them at 3 degrees and then adjust the flange.  Wheels will be a bit smaller but again not a big deal.
« Reply #63 on: November 23, 2018, 11:22:10 PM »
Or you could cut the treads square again, heat shrink a tire on each and cut the proper angle. It probably won't matter for display purposes but I would sure be wanting to run it after investing all that building time.
« Reply #64 on: November 23, 2018, 11:27:10 PM »
I agree that the angle won't really matter. Nor does the exact size. And the fix is not hard if you do as Bill suggests. I don't know how many times something like this has set me on my heels until I've had time to fully appreciate the impact....
Ouch!
« Reply #65 on: November 23, 2018, 11:29:41 PM »
Sorry Kim that's a bummer. :(
If it were me I would either repair them or remake them, I really doubt that I would leave them as is. As Chris indicated maybe you could just re-cut the wheel and reduce the diameter accordianlly. How much would this be on the radius? Maybe not enough to matter.
« Reply #66 on: November 23, 2018, 11:47:14 PM »
That's a bummer and I'm betting you're still kicking yourself over it.
Set it aside. They can wait. Do some other things (i.e. parts) for a while.
The answer may/will come later.
« Reply #67 on: November 24, 2018, 12:17:46 AM »
Thank you all for the commiserations and the suggestions.  I do appreciate it.
Yeah.  I'm feelin' kinda irritated with the whole thing at the moment.  I'll probably just go away and try not to think about it for a while.  If history is any guide, I'll probably feel less down about it tomorrow.  But right now, its pretty much taken the wind out of my sails...
« Reply #68 on: November 24, 2018, 12:23:49 AM »
Nah. Just the wheels. Don't forget about all the good feelings you had with other parts.
Hard to do, but yeah.  ;D
I've stopped projects for less. Don't do that.
I should listen to myself sometimes.
« Reply #69 on: November 24, 2018, 12:38:15 AM »
Assuming you cut the taper so that the flange diameter is intact, then the diameter of the face of the wheel is already a bit smaller.  But cutting the proper taper won't change that; only the flange diameter will end up being reduced.  Based on this and the drawings, I calculated that the wheels are smaller by .049" than per plan.
« Reply #70 on: November 24, 2018, 12:41:50 AM »
So it scales out to  wheels with a bit of wear that the maintenance shop refaced. Realistic!
« Reply #71 on: November 24, 2018, 12:52:53 AM »
If that is correct then the tender would only sit .0245" lower. Negligible for display or running. Sounds like a plan to me.
« Reply #72 on: November 24, 2018, 12:55:42 AM »
I did the same thing and came up with .043" on the radius, but I was only working from the dimensions that I could see in Kim's photos.
« Reply #73 on: November 24, 2018, 02:30:06 AM »
I meant to say the radius.
Measurements done using Draftsght.
« Reply #74 on: November 24, 2018, 03:10:51 AM »
Yes, some time away doing other things was a good idea.  Helps put the world into perspective ;D
Yes, Dave and Kvom, guys have it right.  It would be about 0.043" short on the radius, or 0.086" smaller in diameter (not quite 3/32").  Since the inner diameter is SUPPOSED to be 2 1/16", that would be about 4% smaller.
Now much will that bother me?
I might play with one wheel tomorrow and see how it looks. But right now, I'm kinda thinking that the next several weeks of my shop time will be making 8 more wheels!  But it will go better this time!  And think of the cool paper weights I'll have to sit around my desk?   :-\
How would I learn to pay better attention to the plans if I didn't make stupid mistakes, right?
And it keeps me humble.
