Author Topic: Experiments with capitals for the S&P beam  (Read 13277 times)
Re: Experiments with capitals for the S&P beam
« Reply #15 on: October 20, 2012, 08:55:13 PM »
No
Offline tel
  • Bathurst District, NSW, Oz.
« Reply #16 on: October 20, 2012, 08:58:57 PM »
Bugger! I'll try to get 'em up on Photobucket again and repost the series!
Offline tel
« Reply #17 on: October 20, 2012, 09:13:52 PM »
OK, trying again (sorry about this folks)
« Last Edit: October 20, 2012, 09:18:46 PM by tel »
« Reply #18 on: October 20, 2012, 09:31:55 PM »
Looks really interesting Tel.
Seems like with a profiled inner, the leaves would/could lay against it and look nearly 'embossed?' or as a single part. Thanks for showing.
Offline tel
« Reply #19 on: October 20, 2012, 09:34:13 PM »
Good thinking Carl - might try that for exp #2
Offline tel
« Reply #20 on: October 21, 2012, 02:19:34 AM »
Exp #2 has commenced. First, the recipe as before - turn and trim the case to length.
Second, dig this doohickey out of the drawer and set up the Dremel for a bit of controlled movenement.
Third, slit the case. This time I also managed to remove a bit of the excess material with a bit of manipulation. Now to knock up some sort of profiling tool.
Offline Pete49
« Reply #21 on: October 21, 2012, 03:37:07 AM »
Just watching for a chance to learn some more and OH NO another tool to make. Guess when her indoors gets into me for time spent in the shed the name Tel will come up....he's too far away to listen to her  :lolb: I am learning and will keep watching
« Reply #22 on: October 21, 2012, 08:00:29 AM »
That looks useful :naughty:. Still watching, looking very promising ;).
Offline tel
« Reply #23 on: October 23, 2012, 04:31:11 AM »
OK, the body needs to be a bit shorter, the slots not quite as deep and a bit better shaping up of the 'leaves' but this is getting very close to a capital that I could live with.
Offline Captain Jerry
  • Summerfield, FL USA
« Reply #24 on: October 23, 2012, 04:45:57 AM »
Good stuff, Tel.  Makes me want to build a table engine of some kind.
NOTARY SOJAK
« Reply #25 on: October 23, 2012, 07:57:56 AM »
Looks like you have a solution for the smaller engine :whoohoo:.
Next challenge: for the 1/6th there should be diamonds between each leaf :LittleDevil:.
Offline tel
« Reply #26 on: October 23, 2012, 09:12:18 AM »
My brain hurts when I even consider those diamonds. The only viable thing I have come up with so far is to shape the heads of shortened escutcheon pins and loctite 'em into drilled holes. However, that might not be possible with my #3 - which will be done in 4 pieces, rather than the 3 we have been using thus far.
BTW, these are roughly the size for the 1:6 jobby, with the .308 cases, for the 1:12 you would need to use something like .22rf and a fine slotting saw.
« Reply #27 on: October 23, 2012, 12:00:38 PM »
My supplier still has not come up with the cartridge cases to make these :ShakeHead:.If I am still in need when I get there I might try some tin brass tube. I have a nice 20 thou slitting saw ;)
« Reply #28 on: October 23, 2012, 12:10:11 PM »
Nicely done Tel. Looks well worth the effort!
Offline jonesie
« Reply #29 on: October 23, 2012, 03:24:58 PM »
 :ThumbsUp: tel that is a nice idea for the capitals, i do not think it will take much with a small burr in the dremel and a little filing with some small file and you will have a good looking capital. looks real good.  jonesie
