Author Topic: Experiments with capitals for the S&P beam  (Read 13213 times)
Offline tel
  • Bathurst District, NSW, Oz.
« on: October 19, 2012, 09:21:38 AM »
OK, despite sticking my face out and claiming the 30-06 case would be a good starting point, a quick look this morning didn't turn up any at all (though I know I have some) .... so, a minor change of plan - found heaps and heaps of 308W (7.62 NATO) so, for the first try we will use those.
Re: Experiments with capitals for the S&P beam
« Reply #1 on: October 19, 2012, 09:35:41 AM »
Watching with great interest.
Offline tel
« Reply #2 on: October 19, 2012, 09:43:19 AM »
Oops - a bit of resizing in order. Having problems with my photo hosting service - attachments for the time being I'm afraid.
Step 1; turn away the extractor groove in the bottom of the case and drill what is left of the flash hole out to 6mm.
Step 2; trim the case body down to 25mm length
« Last Edit: October 19, 2012, 09:56:39 AM by tel »
Offline tel
« Reply #3 on: October 19, 2012, 09:46:06 AM »
Step 3; divide a portion of the case (20mm from the open end) into 8 more or less equal segmants
Step 4; cut these segment lines with a Dremel cut-off wheel
Step 5; gently flare out the segments with a pair of long nose pliers.
Offline tel
« Reply #4 on: October 19, 2012, 09:50:39 AM »
Step 6. The insert was turned (reasonable fit inside case) from a piece of 20mm square brass.
Step 7; ... and shoved into the case, seated home with an M6 bolt and nut.
« Last Edit: October 20, 2012, 08:50:41 PM by tel »
Offline tel
« Reply #5 on: October 19, 2012, 09:52:24 AM »
Right way up! Ready for trimming and shaping of the 'petals' - gonna all be hand filing I suspect.
Watch this space.
« Last Edit: October 20, 2012, 02:23:09 AM by tel »
Offline tel
« Reply #6 on: October 20, 2012, 02:21:22 AM »
A long way short of perfect, but on the right track, I think.
Offline Captain Jerry
  • Summerfield, FL USA
« Reply #7 on: October 20, 2012, 02:39:47 AM »
 :thinking: :headscratch: :thinking: :headscratch: :smokin2: :noidea: By George! I think he's got it! :old:
NOTARY SOJAK
Offline tel
« Reply #8 on: October 20, 2012, 08:44:51 AM »
 ;D Well, getting somewhere near it. Now I need to try one with some decent set-ups for the cutting and shaping - that was just knocked out more or less freehand.
« Reply #9 on: October 20, 2012, 10:47:37 AM »
I'm watching Tel!   Can't see your last series of photo's thou. :noidea:
Offline tel
« Reply #10 on: October 20, 2012, 11:09:05 AM »
?? Which ones can't you see?
This was the last one
« Reply #11 on: October 20, 2012, 11:53:26 AM »
Your 4th and 5th post from the 19th of this month.....I can see the first 3 posts pictures.
« Reply #12 on: October 20, 2012, 04:59:35 PM »
Hadn't seen that one. Looks good. :ThumbsUp:
« Reply #13 on: October 20, 2012, 05:22:13 PM »
Looks really good. Interesting process and good use of a spent cartridge.
I don't see the pics in post 6 and 7.
Offline tel
« Reply #14 on: October 20, 2012, 08:52:05 PM »
Can you see 'em now Carl/Dave?
