First a shout-out to Chris. In going through my miniature burrs I happened to have a small container of 3/32 shank burrs that someone gave me quite some time back. I had never used them and didn't even know what the profile was. The tips were so small that I had to use my magnifier to see them and lo and behold they had probably what you called a football shape but more so an inverted tear drop. They have 6 flutes on them and go to a point. I marked my hole locations by rotating my carbide tipped scriber until a had a good witness mark then I chucked up one of the burrs in my Dremel flex shaft. Using my magnifier I carefully set the tip of the burr on the witness mark and lightly pressed down. It didn't skate and gave me a nice dimple to drill to. At that point I was thrilled and the job that I had been dreading turned into not so bad of one. Now to catch up with the build. There's a lot going on at the back of the machine, levers, wheels, handles brackets etc. In my last posting I had presented the bracket and crank mechanism which tilts the axles. Next up was to install the already made axle shift mechanism. This consists of two brackets, one on each side of the rear of the frame. The one on the left holds another set of miter gears, the one on the right just supports the end of the lead screw. The brackets are mounted to a long rectangular plate that the shuttle rides on. The shuttle is made in two pieces and is slotted to fit over the rectangular plate. Attached to it is a bar that hooks to the left side axle yoke. When the handle is turned it transmits motion through the meter gears which turn the lead screw which moves the shuttle. First the full sized machine.
The bracket that supports the shaft for the shifting mechanism is bolted to the frame. This wasn't a particularly hard job but the corner bracket for the platform sits on top of it and the bolts go through both pieces and through the frame. I don't know if having 4 hands would have helped? Trying to hold things in place while scribing lines, what a job. In mounting the operator's platform I had made the angular brackets that go to the frame from my drawing. Well they were just a little off and with the frame tapering it didn't give me enough room to put bolts through the other 3 brackets so they had to be remade. More M1.2x.25 square head nuts and bolts. I think when I get through I'm going to count up all the nuts and bolts I made for this project. Or maybe I don't even want to know!Here's 2 shots of the axle assembly tilted. By turning the crank everything works like it's supposed to.
