Author Topic: Stuart Models Diagram  (Read 1705 times)
Offline bwal
« on: October 05, 2018, 07:47:53 AM »
Hi,
I've just started a Stuart Models ST Oscillating Engine.
I can read the drawings well enough (most of the time) but I'm not sure what "CRS" stands for.  It's after a given dimension.  I kinda thought it meant "near enough is good enough" but I'm not really sure.
Cheers Ben.
Re: Stuart Models Diagram
« Reply #1 on: October 05, 2018, 07:52:07 AM »
It might mean Cold Rolled Steel i.e. it is identifying the material   :noidea:
I have just checked another Stuart drawing... CRS is given on centres measurements of holes so it is short for "Distance between centres"
Offline bwal
« Reply #2 on: October 05, 2018, 08:03:16 AM »
Thank you.
I too, at first, thought it meant cold rolled steel even when I had a brass extrusion in my hand.
Ben,
Offline Lew Hartswick
  • Albuquerque, New Mexico, USA
« Reply #3 on: October 05, 2018, 01:34:10 PM »
A common curse of people that use abbreviations without defining them.  At least the first time they are used in text or a drawing. :-(
   ...lew...
Offline GWRdriver
  • Tennessee USA
« Reply #4 on: October 05, 2018, 02:09:17 PM »
The Stuart (British) equivalent of cold rolled steel would be BMS (bright mild steel.)  CRS, as explained, is for "centers."
Cheers,
Harry
« Reply #5 on: October 05, 2018, 03:32:49 PM »
Hi, Also on an old drawing ..9/64 whit ?????? :???:
Willy
Offline propforward
  • MN, USA
« Reply #6 on: October 05, 2018, 04:10:23 PM »
Whit means whitworth thread, an old British thread that has largely fallen out of use. Only way to get those taps is to import from the UK (if'n you're not a UK type personage).
Here's what the font of all that is knowable and correct with no errors ever, Wikipedia, has to say about it.
https://en.wikipedia.org/wiki/British_Standard_Whitworth
« Last Edit: October 05, 2018, 04:18:47 PM by propforward »
Forging ahead regardless.
Offline bwal
« Reply #7 on: October 05, 2018, 10:56:20 PM »
In regard to the model I'm making, I'm now out approximately 0.4 mm out on the air/steam inlets on the cylinder. The Stuart plans are sometimes funny to read (especially when your converting them to metric).
Ben
« Reply #8 on: October 05, 2018, 11:56:34 PM »
Hi This 9/64 whit thread was on a George Gentry drawing about 1912...!! so where you supposed to make a tap and die yourself  ?? I have looked in all my books and cannot find any reference to this thread  :???: so did he make a mistake or realise this did not exist so just changed it to 4BA but forgot to remove the whit one ??
Willy
Offline propforward
  • MN, USA
« Reply #9 on: October 06, 2018, 12:54:17 AM »
The whit thread was invented in 1841. Can’t speak to availability of taps and dies in 1912 though
Offline propforward
  • MN, USA
« Reply #10 on: October 06, 2018, 03:39:27 AM »
Oh wait, I see what you mean. Maybe 9/64 is the tap drill. Or it's all a huge misunderstanding.
« Reply #11 on: October 06, 2018, 07:07:04 AM »
The die would not have been a problem as most would have been using the two part dies that covered a small range of diameters depending on how close you adjusted the two halves or using a home made die plate . Tap may well have been available.
Offline propforward
  • MN, USA
« Reply #12 on: October 06, 2018, 11:08:00 AM »
That's a nice set.
« Reply #13 on: October 06, 2018, 02:27:13 PM »
Hi Jason , ok that is a really nice set of taps and dies  and i suppose you could make a bolt and a tap to cover a wide range of sizes. I do have some die plates that have a range of "fits" that seem to be a bit confusing ??   I will bring them to Forncett  tomorrow.....
