I'm not sure that you will gain much by case hardening a part like this as it is more to give a wear resistant surface but leave the core soft, if you are hardening to stop the part deforming due to the forces of the press then case hardening is not the way to go.I've not tried the brands you mention but have used a couple of makes available in the UK and they work well giving a surface that a file will skid off but the part does not become brittle.
the diy stuff works but the depth of case is small, a few thou. The depth of case is a function of the soak times, and of all the case hardening methods this is the least effective insofar as depth is concerned. The hardness will be the same as a deeper case, but it will be very thin meaning the part will easily bruise. On model engine parts I've done 2 or three cycles, I also casehardened a set of BA and ME nut drivers I made, it worked very well. Another approach is send it out to a heat treat, they'll soak it overnight and get the thickness up - as much as 50 thou. If you chat them up you can usually get your work thrown in a batch for small dollars. The other thing with this is that you can do it stages - get the soak done but not quenched. say drill and tap a bunch of holes, then get it heat treated and then grind. The result is a dead hard surface but none of the threads are hardened (you don't want hardened threads). The skin is usually left dead hard btw, sometimes an advantage over hardening tool steel and tempering it. I've done this for tool makers blocks, that sort of thing. Works very well, The other way is DIY pack casehardening, you'll get a depth between the two, but its a lot of work (and potential smell). Really only worth it imo if you are shooting for the attractive colour mottled finish (a highlight of quality old tools by Starrett, Lufkin and highly sought after by the gun people).
Don’t forget with a case hardened piece you can reheat it and let it cool slowly and it will have a soft skin , hest it back to cherry and quench and it will be hard again Stuart
he told me that the "old fashion" way would do all that I needed. Just heat it to critical and water quench. He told me that some of the "products" do work but I would not gain that much if any for my application.
now country to how you should do it here's my method part is cold dip it in water then into the powder ,then heat to a cherry red LBSC would have said carrot colour hold for I min per inch thick then quench the accepted method is to get ist red hot then dip it into the powder but IMHO that way contaminates your power I have some old casenite stuff NON H&S as it contains cynanide but it will do a good jobHave fun but be safe
There are lots of old school methods About 60 years ago a friend of my dads ( both passed now ) made very very good 2 1/2 gauge locos and I mead rivet perfect ( this is before cars were common and locos were taken to the track on the back of a motor bike ) Anyway back to the plot he case hardened all the motion and the polished it to a good finish , he used to pack the part in a tin (baccy tin for the small bits ) with bone meal ( ground up animal bone used for garden fertiliser ) and put it in the coal fire before bedtime ,fetched it out in the morning , reheated it to red and quenched this gave it a long soak to get the carbon it Leather also works , as does any thing that has carbon in itBut times were tough then some cheaper method were used , but a good old powder mix was better Btw I was a young 11 years old then but I had been interested in making stuff before then
The 8 hour soak is one I remember as well, and an overnight soak in a damped fire was the method Dad used...This was always a good reference, but there is also a fair bit of info. in Machinery's Handbook on the hardenability of steel. A36 is pretty close to 1018 in hardenability.https://www.emjmetals.com/pdf_indexer/pdfs/Mechanical_Properties_and_Hardenability.pdf
Hello Thomas - I have been AWOL for a while and have only just read your thread.I have had a fair bit of experience in heat treating tool steels and have done a small amount of case hardening - this is both at work and play.With case hardening as has been said the longer the part is in contact with the product - Kasenite, Cherry Red, bone meal etc etc the deeper the 'skin' of the hardened surface. To have anything considered effective this would need to be held at temp for some time - hence the advice of packing the part and material in a container and soaking over night in a fire. Given however you just wish to put a hard surface on the the following should give you what you need. Put some of the Cherry Red powder into a container that the part can be placed in. Heat the part to a good bright red and lay the part into the powder turning it to coat it where you want the hardness. Remove and reheat letting the heat really soak into the part - lay it back in the powder and repeat. It is a hot and smelly process and the part takes on a pretty miserable looking surface blistered and misshapen. That will disappear as soon as you quench it. Keep the heat up and when you are satisfied that you've given it enough treatment quench it - quickly - in clean and quite cold water. I stress that as it's important to get a good result. As said you need to plunge the part into the water really quickly and if Cherry Red responds the same as Kasenite you will hear a sharp crack as it hardens. If you find it has not hardened then reheat to a slightly hotter temperature but importantly change the water - as clean cold water will always give you the best resultsHope that is of help to you - it should give you what you are wanting.Regards - Tug
Hi again Thomas,I cannot see that that would make any difference on 'home' methods other than to stress relieve the part. If you have made it from hot rolled steel as you state as opposed to CRS then what little stress that may be in the part should dissipate in the heat treatment.Something I would add however is that whilst as said it's best to plunge the part into the water as quickly as possible it needs to be as 'evenly as possible' to eliminate any chances of uneven/unequal cooling creating distortion.Good luck with your project Regards - Tug
Hi Thomas,Please note I've added a post script to my last post which you may not be aware ofTug
I have a small part of mild steel for the clutch I am building out for heat treat (case hardening) right now. The person who is looking after it for me is a master machinist with 40 years of experience. I asked him about the idea of me buying the Casenite and case hardening the part myself. He just laughed and said that the amount of depth from a home grown case hardening was very, very little, and not uniform. He sends batch lots of parts out for case hardening to a professional heat treat facility, and tells me that a home brewed case hardening didn't even come close to what would be acceptable. Anything I wanted hardened previous to this was made form 01 steel, heated orange/red and dropped in a container of oil, then 'drawn back' by heating in my wifes kitchen oven for a couple of hours at 350 degrees so it wouldn't be brittle. Not very professional at all, but it does work for me.
Any thoughts as to adding some pre-hardened inserts (0-1, H-13, ETC.) On to the faces of your forming tool? These could be screwed & doweled/pinned on using flat ground stock. John
Started the process of rough milling the Die which is a slow process with a lot of material to be removed. The Die blank is 2-inches wide by 1-3/4-inches high by 12-inches long
Quote from: Ye-Ole Steam Dude on October 07, 2018, 08:40:56 AMStarted the process of rough milling the Die which is a slow process with a lot of material to be removed. The Die blank is 2-inches wide by 1-3/4-inches high by 12-inches long That would be a large piece to quench, more than I would want to do. You have to prepared for the material to move on a heat treatment which is why stuff is usually ground afterward. Small solid shapes are more stable, but that longer shape carries some risk of moving about imo. For brass and AL I'd skip heat treating, safer and no warping. You'll bend a lot of material before wearing it appreciably and even if you did you can resurface. If you are really worried about a wear, I'd make it out some prehardened chrome moly - tough and somewhat hard but still machinableSecond point, whats the angle in the bottom die? it looks like 90. Most of the time in a brake you're air bending and the bottom die has to be less than 90. the material doesn't really contact the sides of the bottom die and you over bend to account for spring. Maybe you're an experienced press hand and i'm telling the choir how to sing...but if not, it'll save you some pain. With an air bend, much less force is required and afaik the most common approach, vs coining or bottom bending. Bend radius is a function of material, bottom die width and top die radius. You also need a radius at the top the V on the bottom die finished to very smooth surface - that's where material will get pulled over the die and that soft stuff will easily scratchIncidentally you can fabricate a bottom die with round bar welde to the top of V block like shapes made of 1/2 plate every few inches. We've done that to get special jobs done. If you used tompson shafting or such you'd start with the bend surface hard and smooth. Probably how i'd go at it.EDIT, for what its worth the above is from experience with steel, I've only done AL and brass in a finger brake, so perhaps I'm not the best one to advise on AL/brass die design....but thats what works with steel
Hi Thomas, I was just playing with Cincinnati calculator (https://www.e-ci.com/press-brake-tonnage-load-calculator/) and those tonnage calcs look a little light in comparison but I'm following what you saying. The cinci calculator is for air bending and is close but a little higher than your numbers. Bottom or coin bending will take 4x the force or more, so am I safe in assuming your numbers are based on an air bend?What I was getting as is to get a 90 degree bend with air bending, you net to bend past 90 (it springs back to 90) so the bottom die V opening is always less than 90 degrees. btw, the DIY bottom die I was trying to describe is sketched below. Its a bit 'quick and dirty' compared to your design which is more solid and how commercial dies look, but it does make for a ready made smooth and hardening opening radius if you use hardened and ground shafting (thompson shafting). Yours is tradition die shape and probably the right way to do it, just offering this up as an another approach. Mike
Please keep the pics coming. I still cannot see you could get an air bend of 90 without the bottom die being less than 90, but you seem well in control so I look forward learning how it all comes together. There seem some slight differences in nomenclature, around here everyone it calls this a press brake and the dies are commonly called upper and lower, vs. die and punch. I think you are more technically correct, I just mention it in case it created confusion; me using the local vernacular.Here's a shot of my brakes, press and finger....big one at the plant and little I made in the garage. If I had one, I like the small hydraulic press idea like you are making....much more capacity than the finger brake I made. The big one is a 16' 300 ton cinci, I've used it but mostly the guys keep me away from it.....they have the impression that anyone from the office will surely destroy it if given half a chance cheers
Hmm. All that work just to fold a dollar bill?
Looks great!We'd each like one...!
Dunno, I kind of like the multi-colored approach. Keeps it easier when talking to the shop assistants - "hand me that thingamajig. No, the purple one"
Quote from: crueby on October 11, 2018, 07:10:19 PMLooks great!We'd each like one...!Hello Chris,I'm telling you, it is as handy as a pocket on a shirt, every shop really does need one. Have a great day,Thomas
Looks like it certainly performed well for its first part!So, what does the top brace do? It doesn't look like it adds rigidity or strength to the press. Are you going to attach it to the wall or something to keep the press from tipping over?Sure looks nice Thomas!Kim
Quote from: Kim on October 13, 2018, 04:15:11 PMLooks like it certainly performed well for its first part!So, what does the top brace do? It doesn't look like it adds rigidity or strength to the press. Are you going to attach it to the wall or something to keep the press from tipping over?Sure looks nice Thomas!KimHello Kim,The top brace is not complete in that photo. I have added a piece of 3/4" 1018 steel round bar vertically in the very center from the Head Beam to the inside of the inverted "V" of the top brace. This acts like a truss and adds a bit more strength to the Head Beam. Although it really is not needed, but it is a part of my original design so I am using it. I could install a 10-ton bottle jack and it would not overload the design.The base legs (16" long each) and the weight of the Press held it securely in place while I was making the first bend. I do have holes drilled in the legs so it can be mounted if needed.Thanks Kim and have a great weekend.Thomas
