Author Topic: Gingery cylinder lap  (Read 1611 times)
Offline oltrucks39
« on: September 30, 2018, 06:52:46 PM »
Hello everyone. Faced with having to lap the DOM cylinder for the Perkins engine I'm building, I came across a nice aluminum lap design in Vince Gingery's book Building the Atkinson Cycle Engine. It uses a 7 degree internal mandrel and matching internal bore on the lap. This design could easily be adapted to virtually any bore size. This bore lap works very well.
Offline Mcgyver
  • Toronto
Re: Gingery cylinder lap
« Reply #1 on: October 03, 2018, 02:35:22 PM »
so the set screw goes in the slot as a key.....how do you adjust the OD?  is there a screw or tap tap tap?
I build one of those engines, a very nice project....myself and I'm sure many here would enjoy photos of your progress
Offline oltrucks39
« Reply #2 on: October 24, 2018, 04:06:43 AM »
There is a bolt (not shown) that threads into the small end of the tapered mandrel that sets the diameter, and then the set screw is tightened to maintain it.
