Author Topic: Unusual Oscillating Cylinder Locomotive  (Read 420 times)
Offline sbwhart
  • Live Long and Prosper
« on: September 30, 2018, 08:14:10 AM »
Thought you chaps would be interested in this. It was acquired by a friend:- Its a four cylinder oscillating locomotive it cam complete with a vertical steel boiler not sure if the cylinders are compounded or not.
Stew
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: Unusual Oscillating Cylinder Locomotive
« Reply #1 on: September 30, 2018, 02:56:55 PM »
Hi Stew.
I know nothing about this engine but my initial thought is that the builder has utilised the castings (fabricated component?)  that would normally have been a cylinder / valve chest and made valve bore operate as a second cylinder  :headscratch:
I can't see how it could operate as a compound unless the low pressure cylinder had a separate valve independent of the rocking motion as at the moment the 2 cylinders are permanently in phase with each other.
It would be interesting to see how the cylinder / portface is machined / drilled, that would tell us a lot  :)
« Last Edit: September 30, 2018, 03:11:12 PM by Gas_mantle »
