Author Topic: 0.6 module involute cutters  (Read 5354 times)
« on: September 28, 2018, 06:02:18 PM »
Can anyone help, please?
I am trying to find some 0.6 module involute cutters to cut the gears for the Jupiter's magneto. The gears in question have 63 teeth and 28 teeth, giving a 2.25 to 1 reduction.
I ordered the two cutters via Aliexpress, they have not arrived after 6 weeks, so we have a payment dispute in progress for non delivery. My problem is, the only places I can find suppliers are also with Aliexpress and I don't want to go down that route again.
Do any of our MEM members have access to 0.6 module involute cutters and would it be possible to borrow them for a few days to cut my 63 teeth and 28 teeth gears. One gear is in Delrin and the other in soft mild steel EN1.
I have tried to identify other gear standards but none match the required tooth count and PCD, so 0.6 module is the only option
Thanks for looking
Offline Stuart
  • Tilchestune UK
Re: 0.6 module involute cutters
« Reply #1 on: September 28, 2018, 06:11:29 PM »
Pour yourself a good sized slug of glenfarclas 105 full cask strength single malt before looking
http://www.tap-die.com/contents/en-uk/d175_Module_MM_Involute_Gear_Cutters.html
Note I am not in any way reponsible for any medical problems ,choking throwing toys out of pram or spitting out of dummies  :stir:
« Reply #2 on: September 28, 2018, 06:17:01 PM »
Hi Stuart
Thanks for the laugh. I did find that one. As you probably guessed, I am not that desperate.
Mike :facepalm: :facepalm:
Offline wirralcnc
« Reply #3 on: September 28, 2018, 06:19:50 PM »
Since they are silly money. What about hpc gears they have what you want at a fraction of the cost. I will have a look in work on tuesday see if we have 0.6 mod cutters.
Robbir
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #4 on: September 28, 2018, 06:21:02 PM »
ShaylocoDan
Offline Stuart
  • Tilchestune UK
« Reply #5 on: September 28, 2018, 06:25:04 PM »
That’s ok Mike
Guessed you had seen that it came up to easy
But we simply to please
Have you seen a program called gearotic ( it’s ok done by art of mach3 fame )
It lets you put in the shaft spacing tooth counts and lets you check for fits etc
If you don’t have it please post the shaft centres and I will run it though to see if any modest price cutters will work
But you could be making a two button form tool to cut the cutter yourself
Have fun in you quest to find the unicorn or pot of gold
I will tune up my Google fu and keep a look out
« Reply #6 on: September 28, 2018, 06:30:23 PM »
I can do the wrong profile  :-\
« Reply #7 on: September 28, 2018, 06:35:38 PM »
Thanks Jo
Getting closer, but no cigar
Mike ;)
« Reply #8 on: September 28, 2018, 06:39:35 PM »
« Reply #9 on: September 28, 2018, 06:42:18 PM »
Here is a source I just located:
http://www.ctctools.biz/hss-involute-module-gear-cutter-set-8pcs-h97/
Dan
Thanks Dan.  Thats a possibility
I have several sets from ctc, used them a lot for brass and aluminum gears. I use Gearotic for quick calculations of gears, also the Ivan Law gear book.
« Reply #10 on: September 28, 2018, 06:48:00 PM »
Robbir
Thanks Robbie.
Yes HPC can provide an off the shelf 28T gear in steel at a reasonable price, but the Delrin 63T is deeply dished so would need to be a one off special. Let's hope my luck is in on Tuesday
« Last Edit: September 28, 2018, 07:10:16 PM by Vixen »
« Reply #11 on: September 28, 2018, 07:02:38 PM »
Thanks Stuart and Crueby
I don't have Gearotic but I have checked for alternatives elsewhere. but not found anything yet. 43DP would be close but I ain't going to find those cutters anywhere. :ThumbsDown: :ThumbsDown:
The gear details are 63t 0.6 module 37.8 PCD, and 28T 0.6 module 16.8 PCD, shaft centres are 27.3 mm.
It would be great if there were an affordable alternative
« Reply #12 on: September 28, 2018, 07:12:58 PM »
Offline Stuart
  • Tilchestune UK
« Reply #13 on: September 28, 2018, 07:13:12 PM »
I will run it though tomorrow if Chris does not beat me to it as my only windoze thingy is in the workshop , it’s all Mac in the house
« Reply #14 on: September 28, 2018, 07:17:04 PM »
Full set on e-bay from Germany, Probably a bonded warehouse for far eastern products but £55 the set
https://www.ebay.co.uk/itm/Involute-Gear-Cutters-Module-Milling-20-gear-cutter-0-6-Bis-6-0-HSS-udssr/183330424887?hash=item2aaf584837:m:mK-F2WVK3uuT-81QVuNLuEA
Hello Jason,
Yep, I found that one as well.  Actually, they were made in the USSR
If you read the small print the cutter which does 63t is missing from the set. About as much use as a chocolate teapot.
« Last Edit: September 28, 2018, 07:22:12 PM by Vixen »
