I am building the circuit ...
Just to remind myself how much I dislike wire-wrap. Didn't mind it much at work with an electric wrap gun and pre-stripped wire ... this hand wrapping and stripping is a bit of a chore too far
Have now done a variant PCB with no wraps but a lot more links. Some you don't win, some you lose ....
You don't need limiter resistors if you set V
supply the same as the LED V
fwd, the current will the be very near to the nominal.
If you count up that piccy, there are 16 segments being driven.
The PSU output current draw is a shade over 170mA
ie. just over 10mA through each segment. Which is more or less what the data sheet says.
If I drop the output to 3.2V they extinguish. 1.6V is not enough to drive the LED ( each of the 2 per segment)
No need to believe me .... try it for yourself ..
Here you are, hang the expense .... snip from data sheet
Disregarding the decimal point, it says ( V
f ) ... Somewhere between 4V and 5V the current will be 20mA through each segment. I'm at 4.2V and about 11-ish mA. Well within the operating area.
