Author Topic: Cleaning castings without a milling machine/lathe  (Read 2058 times)
Offline Smudger
« on: September 17, 2018, 10:42:01 AM »
Hello All
Can anyone tell me if it’s possible to build a stationary model engine from a casting kit with hand tools alone. I do not have a milling machine or a metal turning lathe.
Thanks for reading
Two burning. Two turning. A steady Watch
Re: Cleaning castings without a milling machine/lathe
« Reply #1 on: September 17, 2018, 03:32:36 PM »
Smudger, I would say that nothing is impossible but doing this without a lathe or mill or both would certainly be an uphill battle. In order for such an engine to work the level of precision required virtually dictates that machine tools be used...especially with castings. I suspect you would have far more luck using bar stock rather than castings where sizes are already closer to what is needed for things like the crankshaft etc.  Another option would be to think about building a "tin can" stirling type engine where hand tools would be sufficient. If you are serious about model machining as a hobby, then at some point a lathe and mill will be needed and the membership here can certainly make suggestions for that depending on your budget level. Hope this doesn't deter you but trying to build a working model from castings would simply be a very frustrating exercise which I fear would turn you off to this wonderful hobby.
Offline Tin Falcon
  • Down Jersey USA
Pre machined casting kits.
« Reply #2 on: September 17, 2018, 11:17:30 PM »
@ Smudger
Like bill mentioned nothing is impossible but i dot think anyone here would try it without at least  lathe and some sort of milling attachment or a shaper. If you read the old model making books lathes were crude in the late 1800s and a lot was done with chisel and file .
That being said there are four kits from castings I know of that come pre machined that can easily be assembled with hand tools.
and a variety of price points
https://www.pmmodelengines.com/shop/steam/steam-engine-2am/  $ 98
https://www.pmmodelengines.com/shop/steam/steam-engine-3/   $149
https://www.pmmodelengines.com/shop/steam/steam-engine-8/ $ 179
https://www.pmmodelengines.com/shop/steam/steam-engine-7/  $289
One of these should fit the bill fit the bill
Stuart in the UK also has a full line of pre machined kits.
They seem a bit  pricey but the hours to build one  likely not too terrible.
https://www.stuartmodels.com/products/machined-kits
Another dozen choices price from around  200 GBP to 1200 gbp.
« Last Edit: September 18, 2018, 01:27:14 AM by Tin Falcon »
« Reply #3 on: September 18, 2018, 01:22:09 AM »
Tin, not sure why the topic got locked. I may have done it myself unintentionally. Anyway, I have unlocked it and merged your reply back into the original thread. Sorry for the confusion.
Offline Tin Falcon
  • Down Jersey USA
« Reply #4 on: September 18, 2018, 01:35:11 AM »
 @ Bill: No problem  just tying to get answers to this apparently young and anxious hobbyist.
And @ smudger IMHO a pre machined kit is a great way to get started in this hobby. You can buy a kit or two and assemble with hand tools without the expense and learning curve of owning an operating hand tools. .
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #5 on: September 18, 2018, 01:38:56 AM »
Another source of pre-machined  kits is:
www.grahamind.com
Be sure to go to the downloads section for the brochures and in some  cases the  assembly manuals.
Full disclosure: I designed several of these kits in the 1980's and produced them until 2000 when I turned the business over to my son, Robert, who  still operates  it today.
Gail in NM
Offline Tin Falcon
  • Down Jersey USA
« Reply #6 on: September 18, 2018, 01:46:01 AM »
Gail : i considered adding a link to the kits your son offers but the OP did specify casting kits for whatever reason .  So he now has a few more choices to ponder.
Online Vixen
« Reply #7 on: September 18, 2018, 02:00:33 AM »
Hi Smudger.
Thank you Bill for unlocking this thread
A long time ago there was a series of articles in Model engineer Magazine titled "Handmaiden by Tubal Cain". Tubal Cain was a highly accomplished model engineer of the time. As the name implies Handmaiden was a hand made (no machine tools) horizontal engine, a Stuart 10H. The series ran on alternative issues from June 1982 vol 148 and into vol 149. He built the engine entirely by hand, to prove it could be done without machine tools.
Ask the forum members if they have a copy of the ME series or you could contact ME directly on www.model-engineer.co.uk/forums/
From your sign off, do I detect you spend a lot of time at sea?
Good luck
« Reply #8 on: September 18, 2018, 07:01:48 AM »
I did reply on ME forum as this one had been locked and mentioned Handmaiden which was a slightly modified 10H to make it a little easier to make by hand
It is important to remember the likes of Tubal Cain served an engineering apprenticship and would have spent many months stood infront of a vice learning how to file and fit parts and would not have been let near a machine tool for at least a year or two. This plus a hacksaw was all that he used to make the engine plush some bought in nuts, bolts and the drain cocks.
Online Vixen
« Reply #9 on: September 18, 2018, 09:35:38 AM »
Jason,
Sorry, I did not see your reply to this on another forum. I was not trying to steal your thunder
Offline Smudger
« Reply #10 on: September 18, 2018, 10:00:46 AM »
Thanks everyone for the information plenty to think about and a lot more research needed. Most grateful for your help
Offline Tin Falcon
  • Down Jersey USA
« Reply #11 on: September 18, 2018, 11:25:40 AM »
That kit is available from Stuart  for 89 gbp  ex VAT
« Reply #12 on: September 18, 2018, 11:42:53 AM »
Mike, no problem. As I said I would have posted here as that is where I saw the question first except the thread had been locked. Added the couple of photos to this thread too as I thought others may be interested to see what can be done with very little in the right hands, makes you wonder why some people feel the need for several Lathes and mills :LittleDevil:
Unfortunately I only have Vol 148 and not 149 which has the majority of the build in it.
Online Vixen
« Reply #13 on: September 18, 2018, 11:58:29 AM »
Smudger, Jason
I find I have Model Engineer vol 148 and vol 149 hidden away in the spare bedroom.  These contain all the Handmaiden articles and more. That's 24 magazines in total, so quite heavy. I can wrap them up and post them to Smudger (first in line) if he /or anyone else covers the shipping costs. I also have the complete Model Engineer volumes 148 through to volume 169 available, yours for the shipping costs.
Offline AOG
« Reply #14 on: September 18, 2018, 01:00:24 PM »
www.grahamind.com
Gail in NM
I can’t recommend these kits highly enough. I built them before I had any machines and I had a lot of fun. Best of all they are pretty small and you can take them with you. I made several of them in hotel rooms while I was traveling for work. As an aside, thank you Gail for designing these kits. They were my gateway drug into this hobby. If it wasn’t for them I wouldn’t be here.
Tony
