Author Topic: 1898 Automobile A.K.A. horseless carriage  (Read 72127 times)
« Reply #375 on: May 17, 2019, 05:06:15 PM »
You are making short work of that list Thomas. It's really coming back together nicely now.
Hello Bill,
Thank you, getting started early every morning and almost everything going my way and not too many "hick-ups". I am going to upload photos in a minute showing completed work as of today which is now all Steps through 13.
« Reply #376 on: May 17, 2019, 05:13:02 PM »
Hello everyone,
Getting started at 2:am in the mornings allows me to get a lot of work completed before my old body gives out. Anyway I am attaching four photos showing the current status of the Chassis. The Front Axle is now completed and fully installed with only some fine tuning on the Tie Rods to adjust Toe-in and Toe-out. Now all Steps through #13 are now completed. Waiting on more bolts and nuts to start back to work on the Engine Frame.
Photo 1, front view with the competed Axle installed
Photo 2, close up of the Spring assembly
Photo 3, rear view of the Spring, Spindle, Tie Rod and Rack & Pinion
Photo 4, rear view of the complete Axle, Rack & Pinion and both Link Bars
« Reply #377 on: May 19, 2019, 07:56:14 AM »
Still following along and enjoying  :ThumbsUp:  :ThumbsUp:  :wine1: You have had your fair share of mishaps. I think you should add a cushion to the milkcrate to protect your back  :)
« Reply #378 on: May 19, 2019, 09:34:39 AM »
Hello Roger,
Great idea and I'm thinking a lap belt for added safety :Lol:
« Reply #379 on: May 21, 2019, 11:57:00 AM »
Hello everyone,
Yesterday I worked on the Engine Frame and installed all the bolts, washers and locknuts that go on the Closed Axle Flanged Bearings. Made a small booboo by not centering the Driven Axle before tightening all of the Bolts. No real biggie, tomorrow I can correct that before moving on.
Photo #1, showing the Engine Frame upside down and all the Bolts in place
Photo #2, close up of one of the four Axle Flanges and the Flange Bearing now bolted in place
« Reply #380 on: May 21, 2019, 08:32:45 PM »
 8)
The weather is hopefully clearing, and floodwaters receding enough for that upcoming test drive!   :ROFL:
Keep up the good work, Thomas, it's coming right along. :popcorn:
« Reply #381 on: May 21, 2019, 09:28:04 PM »
8)
Hello Bent,
Not to worry about high water, the Buggy has almost 11-inches of clearance :ROFL: to the drive train.
Thank you and have a great day,
« Reply #382 on: May 21, 2019, 09:49:47 PM »
Hello everyone,
Today I machined two new Spacer/Bushings out of some aluminum round bar and they are .7980 inches long. The attached photos will show where they go on the Rear Axle. The discoloration on the Axle is not rust, it is the protective copper coating (Cop-Graf) that I applied when I installed the Axle.
Photo #1, shows the Spacer/Bushing on the Axle next to the Flange Bearing
Photo #2, shows the Wheel Hub Adapter pushed up to the Spacer/Bushing
This arrangement establishes a “ set / fixed “ spacing between the Wheels ( tread width ) once the Axle is centered.
« Reply #383 on: May 22, 2019, 12:56:22 AM »
More good progress Thomas. Always good to see an update.
« Reply #384 on: May 22, 2019, 02:14:37 AM »
Hello Bill,
My plan is to (hopefully) get the Jackshaft and the Transmission mounted on the Engine Frame tomorrow. If that goes well, might even get at least one chain cut to length and installed.
« Reply #385 on: May 22, 2019, 09:52:16 PM »
Hello everyone,
Well I did not get near as much accomplished today as planned. Nothing seemed to go right starting with a factory defect in one of the threaded holes on the Transmission. There are four bolts that hold down the Transmission and one of the threaded holes had only a few threads which I did not discover until I had installed the other three.
Photo #1, shows the underside of the Engine Frame and my Hand Tap going into the Transmission re-tapping the hole
Photo #2, shows the Transmission with the Driven Pulley now installed and the Jackshaft temporarily installed
I did get all the Set Screws tightened down and all of the Key Stock cut to size and installed. I deserve a big relaxing drink tonight :wine1: :cheers: :cheers: :cheers:
« Reply #386 on: May 23, 2019, 10:25:34 PM »
Progress is being made, so libations are allowable.  In other words, have two!
« Reply #387 on: May 23, 2019, 10:31:01 PM »
Hello Bent,
Man after the day that I had, two was just a start  :LittleDevil:
« Reply #388 on: May 23, 2019, 11:26:05 PM »
Hang in there Thomas. It will all come together!!
« Reply #389 on: May 24, 2019, 02:09:05 AM »
Thanks Bill.
