Author Topic: 1898 Automobile A.K.A. horseless carriage  (Read 34666 times)
« Reply #390 on: May 24, 2019, 04:39:34 PM »
Thomas--You are going to need an outboard bearing and support on the cantilevered end of the shaft with the pulley on it.---Brian
« Reply #391 on: May 24, 2019, 05:01:12 PM »
Brian,
Maybe...but, those units are made to hold up to the belt loads up to the rated hp.  Adding an outboard bearing will make it more difficult to replace the belt.
« Reply #392 on: May 24, 2019, 06:14:12 PM »
Hello Brian,
Yes you are correct and I have already built one, see the attached youtube video showing the unit. I posted about this unit couple of months ago.
Thank you and have a great day,
« Reply #393 on: May 24, 2019, 06:17:20 PM »
Brian,
Hello Bent,
See what I did on the youtube video I added to Brian's post. You will see that the whole unit can be removed so that I can replace the Belt and or the Driven Pulley with no problem.
Have a great day,
« Reply #394 on: May 24, 2019, 06:32:56 PM »
Hello  @b.lindsey
Bill I have tried to send you a PM two times but it doesn't appear to have worked. If you can, send me a PM. If you can see my direct email on my Profile, send me an email.
Have a great day,
« Last Edit: May 24, 2019, 06:40:46 PM by Ye-Ole Steam Dude »
« Reply #395 on: May 24, 2019, 10:48:10 PM »
Hello everyone,
Well another unexpected setback in my progress, but this time it is my fault. I read and “interpreted “ the required spacing distance needed between the inside of the Driven Clutch and any obstruction was to be a minimum of 1/2-inch. On my design I allowed for 5/8-inch which should have been enough. However, it turns out that the minimum spacing should be closer to 3/4-inch. So after considering many options I decided to cut a notch in the square tubing of 3/4-inch which is a bit more along with the already 5/8-inch. To close up the tubing where the notch was made, I cut and bent to shape some flat bar and welded it in place. Cleaning the area around where I torch cut and then spraying on two coats of primer took most of the day. I did get the first coat of black applied and will let that dry until tomorrow. It will be some time next week before I can start back installing the Transmission and other components.
Photo #1 & #2, shows the flat bar cut and bent to shape that was used to close up the tubing
Photo #3 & #4, shows the new “notched” area in the tubing
Have a great day,
« Reply #396 on: May 24, 2019, 11:35:35 PM »
Thomas, I did receive the pm's. Have replied now. Sorry for the delay, just a busy day getting things finalized on the house.
« Reply #397 on: May 29, 2019, 08:05:07 PM »
Hello everyone,
I am attaching another video showing all the work that has been completed to date, this is Part-15 of the build series. All of the modifications to the Engine Frame are now completed and final reassembly of all the components are now underway.
Have a great day,
« Reply #398 on: May 29, 2019, 08:16:42 PM »
Looking great Thomas, quite a nice bit of engineering and construction!
I'll be keeping an eye out for your shop elves zipping past my house on it...
« Reply #399 on: May 29, 2019, 08:26:02 PM »
Hello Chris and thank you,
I am really getting close to doing and Engine run test. Bunch of small items like cutting to length on the Chains, applying Loctite to all the set screws ( man there are a lot of those ) and etc but no major items. I need to make a temporary Battery tray so that I can mount the Battery and make the cables to size. Most likely several more days and then the "big bang".... :lolb:
Have a great day,
« Reply #400 on: May 30, 2019, 12:30:46 AM »
Great Thomas...looking forward to that!!
« Reply #401 on: May 30, 2019, 12:45:11 AM »
Hello Bill,
So am I....for a long time now :ROFL:
Have a great day,
« Reply #402 on: May 30, 2019, 04:12:48 PM »
Hello everyone,
Just a quick update showing the Transmission, Jackshaft and both #40 Chains cut to length and now in place. Hand turning the Driven Pulley moves everything smoothly and that makes me very happy.  :cartwheel: :pinkelephant: :whoohoo:
Next up is to finish applying Loctite to all the set screws and double checking all bolts and nuts and then mounting of the Engine.
Have a great day,
« Reply #403 on: May 30, 2019, 05:18:31 PM »
Awesome!
« Reply #404 on: May 30, 2019, 05:38:07 PM »
Good progress Thomas!
