Author Topic: an adventure in the mini lathe world  (Read 1931 times)
Offline Ratchap
« on: August 22, 2018, 09:58:29 PM »
Greetings from West London, I was suggested i start to  show  what i was doing / planning/ dreaming of  with my  freebie  mini lathe. it is going to be used for making parts  for my 7mm to the foot  model railways
I understand it is a  Norfolk lathe of 1960's era  I was given it 7 years ago and only just have managed to get a motor fitted apart from the motor  what you see in the picture is what i was given
an independent 4 jaw chuck , 2 dead centers a back plate a couple of HSS tools and the Allen keys.
since getting the motor and fixing every thing down i  have started on a list of needs  and wants
needs.To replce the motor pulley  with one the same size as the lathes to  enable simple  speed changing
a 3 jaw chuck  or collet holder to  mount on the back plate
alive centre
a drill chuck for the tail stock
some form of calibration for the cross slide and compound slide
means of screw cutting ( i am thinking a stepper drive and arduino
wants
some form of split lead screw  mechanism as its a lot of work to wind the tool post  all the  way  from  head to  tail
improve the hand wheels
a cover for the pulleys  on the lathe
a milling vice  for the cross slide
I hope that these projects may be of interest
« Last Edit: August 22, 2018, 10:08:27 PM by Ratchap »
what do you mean it wont fit  Get a bigger hammer
Re: an adventure in the mini lathe world
« Reply #1 on: August 22, 2018, 10:24:32 PM »
Nice looking little lathe Nigel. Is the spindle nose threaded and if so what size? I like the robyst handles on the tailstock and toolpost as well.
Offline Ratchap
« Reply #2 on: August 22, 2018, 10:30:48 PM »
the spindle nose IS threaded  and i am told its 1/2 inch UNF  i have a set of unf  thread gauges on order  from Amazon  ((  other suppliers are out there)
« Reply #3 on: August 22, 2018, 10:54:54 PM »
It may not be of help in the UK but the 2.5" Sherline 3jaw Chuck is available with 1/2-20 threads if that is what the spindle nose turns out to be. https://www.sherline.com/product-category/chucks-collets/scroll-chucks/
Offline Ratchap
« Reply #4 on: August 23, 2018, 12:30:00 PM »
cheers Bill  only trouble is the price  !! I have ordered a ER32  chuck to  mount on the back-plate which will do  most of what i  want  in conjunction with the 4 jaw chuck als ordered a nice little  tailstock from amazon  should be here ( at work) this afternoon  will add some pictures and a little write up of the plans for it later
Offline Ratchap
« Reply #5 on: August 23, 2018, 09:45:43 PM »
the live center has arrived  and  nice piece of work it is, the holder will be replaced  as it does not line up height wize  so somple bit of  bllock cutting  and drilling should sort it  out
« Last Edit: August 23, 2018, 09:54:57 PM by Ratchap »
Offline Ratchap
« Reply #6 on: August 27, 2018, 08:56:27 PM »
well i got  some 14mm  nuts  and 1/2 unf  nuts
the /2 inch one  will not even start  the 14mm one goes on 1 or 2 turns any ideas ?
Offline AOG
« Reply #7 on: August 27, 2018, 09:20:59 PM »
Donít forget that there are also 1/2 unc. 1/2 UNF is 1/2 by 20 TPI . 1/2 UNC is 1/2 by 13 TPI. You might try that.
Tony
Offline John Hill
  • Playing in my shed at Ashburton, New Zealand.
« Reply #8 on: August 27, 2018, 09:39:47 PM »
Nice little lathe!
I suggest you include a layshaft to reduce the drive speeds as I assume the spindle bearings are plain bushes and will not appreciate the sort of high speeds the current set up could provide.
I have a Flexispeed lathe that is very similar and find it a joy to use for those small jobs!
Offline Ratchap
« Reply #9 on: August 27, 2018, 10:12:27 PM »
cheers  Tony  i will order a selection  of nuts  lol
john the 1st job i  am going to  do is to make another  3 step pulley  the same size as on the lathe  fit this to  a Layshaft  I have got a length of SS rod  and some Pillow bearings on order   will just need to  source   the drive pulley  and build a framework.
I have a chunk of ally  centered in the 4 jaw chuck ready to face off  center  pop  and  turn to size  starting on wed
« Last Edit: August 27, 2018, 10:15:35 PM by Ratchap »
« Reply #10 on: August 27, 2018, 10:27:40 PM »
Just catching up on this thread, when my eyeballs tripped over the statement
Never seen that scale before, or actually even one that mixes mm's and feet (started to type 'foot's'  :Lol: ). Is that a common scale in the UK?
Nice looking old lathe, looking forward to seeing parts from it!
Offline Ian S C
« Reply #11 on: August 28, 2018, 03:01:43 AM »
A wee trap with threads, 1/2" UNC 13 TPI,  !/2" BSW 12 TPI.  There is more than the standard meric coarse too.
Ian S C
Offline John Hill
« Reply #12 on: August 28, 2018, 08:08:59 AM »
Hi Ratchap,  I measured my Flexispeed spindle thread and it is 1/2 x 16TPI presumably  BSF. I think your Norfolk will be the same.
« Last Edit: August 28, 2018, 08:17:08 AM by John Hill »
Offline Ratchap
« Reply #13 on: August 28, 2018, 10:22:44 AM »
7mm to the foot is  also  known as 0 scale,  4mm to the foot is 00 scale, 3.5mm is HO scale   (mostly used in Mainland Europe) , 3mm  is TT scale, 2mm to the foot is N gauge, 1mm is Z gauge
there is an pure imperial scale  of 3/16 to the foot    called S scale  wikipedia has articles on all these.
a lot of modelers swap scale and gauge  there are also a range of  variations   which use  1 gauges track  and another scale
confused ?    im not surprised
Offline Ratchap
« Reply #14 on: August 28, 2018, 10:29:15 AM »
Cheers John  i  will  try my thread gauge  when i  get home plus I  have ordered  some nuts  in that  size
