My drawings are copyright Hemingway 1993 but I believe that almost identical drawings are available from all over.
Last night I realised I had made a mistake
the two holes on each link need to be on the same side so first thing this morning I set about correcting them. First I turned four steel plugs the size of the offending holes:
I then silver soldered them in:
They clean up quiet well:
I then proceeded to mill the slots in the larger link. Before taking it to my Hobbymat lathe and milling parallel sections where the tapers will be on both links:
One of my complaints about the hobbymat is that the tool post and cross slide gets in the way when I want to support anything from the tailstock. So I proceeded inside to use the Cowell?s to turn the tapers on the smaller link:
The taper has been hand formed I simply cut the two end diameters, then manually made a number of steps and merged them using a needle file.
I then returned to the hobbymat and set over the top slide and turned the tapers on the larger pair of links:
Next job turn the centres of the two links the correct diameter to fit in the weights:
Now for a bit of filing. I thought you might find my ?fiddly bit vice? interesting. I made this up out of a locking ball join clamp with a toolmakers vice mounted in the socket. The result is a vice that can hold small bits in any orientation you may ever need.
The links are very fragile once the ends are broken so it is important to put a packing piece between the arms when you file or nasty things will happen:
Before filing the larger link it was necessary to bring the 6.35mm square down to a 4.7mm by 6.35 section on the end balls, 4.0 by 6.35 on the arms and 4.7 by 4.7 where the central pivots are:
So tonight two links still together:
And just to check they fit.
I still need to make the pivots, drill the weights and make the last two pairs of links.
That is it for today, this evening I am off to my Model Engineering Society to see if they are going to run a Rally next year.
