Author Topic: GDB Inline 4 Cylinder OHV I.C.  (Read 35024 times)
Re: GDB Inline 4 Cylinder OHV I.C.
« Reply #45 on: September 18, 2018, 12:12:14 AM »
Bob,
I started taking Wal-itin by my doctors recomendation it's Walgreen's generic version. Other wise I'd be blowing my nose all summer, oh yeah and sneezing to.
Offline 90LX_Notch
    • YouTube Channel
« Reply #46 on: September 24, 2018, 12:16:11 AM »
Block continued-
The cam tunnel calls for a .312 diameter hole, 4.523 deep.  In order to get good geometry, the engine block was setup on an angle plate on the faceplate of the Rivett.  A toolmaker's button was used to locate the center point of the block.  As of right now, I am about halfway through the block with a .250 pilot hole.  It is taking an extremely long time to drill the pilot because the lathe is in backgear and the surface speed is far below what a .250 drill requires.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline 90LX_Notch
    • YouTube Channel
« Reply #47 on: September 24, 2018, 12:17:17 AM »
Thanks Art for the tip.  Unfortunatly, there aren't any Walgreen's near me.
-Bob
Proud Member of MEM
« Reply #48 on: September 24, 2018, 12:56:31 AM »
That's quite a set up Bob!! Hope the allergies are better now.
Offline 90LX_Notch
    • YouTube Channel
« Reply #49 on: September 25, 2018, 12:16:28 AM »
Thanks Bill.  My allergies were bad Friday and Saturday.  They were good yesterday.  I should have quit while I was ahead though.  I had a little mishap with the block. The boring bar rubbed and the block shifted on the angle plate.  I believe it is recoverable.  I just have to add an extra step to the plan that I had in mind.
-Bob
Proud Member of MEM
Offline gldavison
  • Tarkio, Mo.
« Reply #50 on: September 28, 2018, 04:20:12 PM »
Hi Bob
 Just caught up on this build. Excellent work so far. I'll be following along. Did George have a build thread on this engine? I need a project for this winter, and this looks like a good one. So I need plans.
Gary
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
« Reply #51 on: September 28, 2018, 07:03:37 PM »
HI Garry,
There is no build thread as it was made long before I had a computer or digital camera. I do have the drawings. Send me a personal email and I'll give you the particulars.
Offline 90LX_Notch
    • YouTube Channel
« Reply #52 on: September 30, 2018, 11:42:29 PM »
Thanks for following along Gary.
It will be nice if you pursue this engine also.  If we can get a third person (come on Bill), it will be the "Tiny" builds of a couple of years ago all over again.
-Bob
Proud Member of MEM
Offline 90LX_Notch
    • YouTube Channel
« Reply #53 on: September 30, 2018, 11:43:50 PM »
Unfortunately, I couldn't squeeze in any shop time this weekend.
-Bob
Proud Member of MEM
Offline 90LX_Notch
    • YouTube Channel
« Reply #54 on: November 26, 2018, 03:06:17 AM »
Well, it has been close to two months since I last posted in this thread.  Life has gotten in the way of any shop time.  However, I was able to get in the shop today and made a .250 diameter by six inch long boring bar.  The bar uses #44 (.086) drill rod as an insert tool bit.  I proofed it on a piece of 7075 aluminum using the above setup (faceplate and angle plate) and successfully bored a .300 dia, 1.5 inches deep.  Unfortunately, when I went to take a picture, the camera batteries were dead.
Hopefully, I can get more shop time in and start to move forward with this build.  Unfortunately, this winter is already stacking up to be bad.  We had a 10" storm hit us last Thursday and I have been called out several times since, for icey road conditions.
-Bob
Proud Member of MEM
« Reply #55 on: November 26, 2018, 11:18:08 AM »
I hear ya buddy!   Stick with it, it'll come back and winter wont last for ever....... 8)
Offline 90LX_Notch
    • YouTube Channel
« Reply #56 on: December 16, 2018, 08:16:09 PM »
Thanks for looking in Dave.
Block continued-
As mentioned above, I made up .250 dia boring bar.  It worked well enough to get the job done.  The cam tunnel is now through the block.
With Cabin Fever fast approching I have decided to put this build on hold (as though I was making any real progress) and try to finish up an engine that I started on years ago.  If I pull that one off in time for CF it will be a pretty neat little engine.
-Bob
Proud Member of MEM
« Reply #57 on: December 16, 2018, 10:09:02 PM »
Man I love that lathe......parts look good too!
« Reply #58 on: December 16, 2018, 11:41:36 PM »
Nice work Bob, and yes what Dave said, I sure wouldn't mind having that lathe in my shop.
« Reply #59 on: December 17, 2018, 12:03:36 AM »
Your setups always amaze me too Bob. The block is coming along.
