Author Topic: GDB Inline 4 Cylinder OHV I.C.  (Read 35729 times)
Offline 90LX_Notch
    • YouTube Channel
Re: GDB Inline 4 Cylinder OHV I.C.
« Reply #30 on: September 06, 2018, 11:34:40 PM »
Thanks Eric.  Maybe a shoe box to transport this one.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline 90LX_Notch
    • YouTube Channel
« Reply #31 on: September 06, 2018, 11:41:37 PM »
Block continued-
The tangent points of the two internal radii needed to be milled in a straight line along with the outside of the wall. In order to align the radii, two ball bearings and tool blank were used.  This worked well and the tangents were sucessfully blended.  Next the outside of the wall was milled.
-Bob
Proud Member of MEM
« Reply #32 on: September 07, 2018, 12:13:21 AM »
Neat!
« Reply #33 on: September 07, 2018, 12:57:26 AM »
Yeah, neat trick Bob. Have to file that one away.
« Reply #34 on: September 07, 2018, 01:13:50 AM »
Nicely done Bob!
Offline 90LX_Notch
    • YouTube Channel
« Reply #35 on: September 07, 2018, 02:07:28 AM »
As always, thank you gentlemen for your support.
I posted the bearing trick in "Tip and Tricks" with a writeup.
-Bob
Proud Member of MEM
« Reply #36 on: September 07, 2018, 08:45:48 AM »
Off to a great start  :ThumbsUp:  :ThumbsUp:  :wine1:
Offline 90LX_Notch
    • YouTube Channel
« Reply #37 on: September 09, 2018, 04:27:52 PM »
Block continued-
The timing case feature is now complete, sans the threaded holes for the cover and some additional handwork.  The .062 radius on the outside back edge was done with a lathe tool that was mounted in a fly cutter.  The spindle was locked in position and the Rotary Table was cranked and acted like a Planar with the tool being fed in small increments.  This allowed the cutter to cut right up to the corners without trailing away as would happen if the tool was turning in the spindle.
The outside of the small radius for the wall, which was machined in the above post were the tangent was milled, was done in a similar fashion.  The boring bar was mounted 180 degrees out from normal as if to cut an od with the boring head.  The boring head was carefully turned back and forth by hand.  After each cut, Z was increased .010 and the motion was repeated until the depth of the wall was fully cut.
-Bob
Proud Member of MEM
Offline 90LX_Notch
    • YouTube Channel
« Reply #38 on: September 09, 2018, 04:28:52 PM »
Thanks Roger for your support.
-Bob
Proud Member of MEM
« Reply #39 on: September 09, 2018, 06:57:52 PM »
Good to see you getting some shop time Bob. The block is coming along well.
Offline 90LX_Notch
    • YouTube Channel
« Reply #40 on: September 17, 2018, 03:18:12 AM »
As always Bill, thank you for following along.
For a couple of different reasons I put the block on hold.  My allergies have been bad and the block requires more concentration than I am able to muster at this point.  Secondly, I have the Rivett 608 up on blocks incase the basement floods as Florence moves this way.  I was planning on boring the cam tunnel next and was going to set it up on the Rivett with an angle plate bolted to the faceplate.
Crankcase breather-
In order to keep this build moving, I picked off a part that I could get through with my allergy situation.  I started the crankcase breather assembly by making the flange.  I started with a piece of .750 diameter aluminum and roughed out a blank.   The blank was then mounted to the .187 dia. expanding collet that I used for the flywheels in the "Tiny I.C." build.  The collet was used to face the back of the blank and was then transfered to a Vee Block, which was setup on the Rotary table.  The bolt holes were drilled along with one hole into the collet that allowed the blank to be pinned to help prevent it from moving during milling. The basic profile for the flange was then milled.  The smaller radii were filed by hand.
-Bob
Proud Member of MEM
« Reply #41 on: September 17, 2018, 04:03:44 AM »
Bob,
Just in case I haven't chimed in yet I wanted to let you know that I'm following along. I have a great respect for George and it is great to start to see people building his designs. Great work so far.
« Reply #42 on: September 17, 2018, 05:48:29 AM »
Nice little part there, Bob.
Sorry about the allergy situation.  That's no fun at all. Hope it gets better soon!
Offline 90LX_Notch
    • YouTube Channel
« Reply #43 on: September 17, 2018, 10:49:42 PM »
Thanks Art for following along as well as your kind compliment.
Thanks Kim.  Yeah, allergies are not fun at all.  I try very hard not to take anything for them and usually they clear up within a day or two on their own.  The fall is a particularly bad time for me.
-Bob
Proud Member of MEM
« Reply #44 on: September 17, 2018, 11:41:16 PM »
 :popcorn: Following along.
Try not to sneeze in the shop. Those small parts will fly.
