Author Topic: GDB Inline 4 Cylinder OHV I.C.  (Read 35815 times)
Re: GDB Inline 4 Cylinder OHV I.C.
« Reply #120 on: April 15, 2020, 02:08:02 AM »
Very nice work Bob.  :popcorn: :popcorn: :popcorn:
Offline scc
  • Lancashire, UK
« Reply #121 on: April 15, 2020, 11:22:26 AM »
Absolutely beautiful machining Bob :praise2: :praise2:        My attempts at accurate handwheel turning are far below yours.......inadequate concentration ::)         Love this build :popcorn: :popcorn:            Regards     Terry
Offline 90LX_Notch
    • YouTube Channel
« Reply #122 on: April 17, 2020, 01:12:12 AM »
Thank you Craig.
Thanks Terry.  I have notes by the machine indicating the direction the part is being machined based on what the numbers on the dials are doing.
 My notes look like this:
Cut to Left X minus
Cut to Right X plus
Cut to Back Y minus
Cut to Front Y plus
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #123 on: April 17, 2020, 06:39:53 AM »
Hi Bob, very impressive.
Offline 90LX_Notch
    • YouTube Channel
« Reply #124 on: April 21, 2020, 11:49:47 PM »
Thanks Achim for your continued support.
-Bob
Proud Member of MEM
Offline 90LX_Notch
    • YouTube Channel
« Reply #125 on: April 21, 2020, 11:50:06 PM »
Main Caps-
I decided to take a little deviation and start on the main caps.  The rough shape was milled and then setup on an arbor in the lathe.  A Dremel was used to profile the required .275 radius.  I've posted about this technique before, but in a nutshell, the Dremel is set on the tangent and is run back and forth until the profile is produced.
Next, the profiled bar was setup in the mill and a .014 slitting saw was used to slice off the caps.
The caps will be drilled in the mill.  The same fixture plate that was used for locating the block will be used.  A .250 pin that sits in a radiused groove in the fixture is used to locate the caps.
-Bob
Proud Member of MEM
Offline 90LX_Notch
    • YouTube Channel
« Reply #126 on: April 04, 2021, 03:48:18 PM »
Well it’s been close to a year without any updates.  I did continue to work on this but just didn’t post anything for some of the reasons that were brought up in the “Lack of response to posts” thread.  But, a major factor was that my technology had become very outdated.  It was ten times harder to move, convert and post pictures.
 The attached picture is a “family” shot.  The oil pan and main caps are done.  The timing cover is done.  The tappet cover is done and the water pump is half done.
I do have some pictures of each part being machined if there is any interest.
-Bob
Proud Member of MEM
Online Vixen
« Reply #127 on: April 04, 2021, 04:44:59 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp:
Just to let you know it's looking good.
Online Roger B
« Reply #128 on: April 04, 2021, 05:51:19 PM »
That's some machining to be proud of  :praise2:  :praise2:  :wine1:
I am interested in function, I don't have the patience for finishes like that  :(
Offline 90LX_Notch
    • YouTube Channel
« Reply #129 on: April 04, 2021, 06:09:43 PM »
Thanks Mike, knowing your work, that is a great compliment.
Thank you Roger.   The finish isn’t all that hard to achieve. Sandpaper to remove tool marks and green Scotchbright for the final finish.  I try keep the same stroke direction to give a grain appearance.
-Bob
Proud Member of MEM
Offline kuhncw
« Reply #130 on: April 04, 2021, 06:13:07 PM »
Bob,
Nice work.  Photos of a few more parts being machined would be interesting.  I always learn from the setups others devise to hold parts.
Chuck
« Reply #131 on: April 04, 2021, 09:09:41 PM »
Looks really good to me + nice to see that you still progress with this engine.
You mention that the finish is only 'sandpaper' - but it still requires the correct technique or you end up with a lot off lines criss crossing each other in odd angles ...  :ThumbsUp:
Offline gldavison
  • Tarkio, Mo.
« Reply #132 on: April 05, 2021, 12:44:08 AM »
Beautiful work Bob. I begin to wonder if you were still going to work on this. I understand about life getting in the way of the hobby. I check in every day hoping to see some progress.
I'm with Rodger on the finishing part. I'm just interested in seeing the work run when I get done. Maybe if I live long enough the better finishes will come along.
Gary
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline 90LX_Notch
    • YouTube Channel
« Reply #133 on: April 05, 2021, 01:59:54 AM »
Thank you Chuck.  I will start posting pictures.
Thank you Admiral for your continued support.
Thank you Gary.  Hopefully, I can get some momentum going.
-Bob
Proud Member of MEM
Offline 90LX_Notch
    • YouTube Channel
« Reply #134 on: April 05, 2021, 02:24:59 AM »
Main Caps continued-
A .250 diameter pin was placed in a collet.  A driver was threaded onto the Atlas 618 spindle and a previous attempt at the main caps was placed on the .250 pin.  A lathe dog was clamped onto the assembly.  This setup created a fixture to screw the main caps onto for facing.  The caps were then faced on both sides to the proper width while maintaining alignment with the caps center line.
-Bob
Proud Member of MEM
Database Error
Back
