Author Topic: jonesie's simpson and shipton  (Read 8211 times)
Offline jonesie
« on: October 16, 2012, 04:37:38 AM »
here is a pic of some off my progress of my simpson and shipson by stew hart.need to cut the radius's on the cylinder side plates.there are lots of small parts so build is slow.hope to turn the flywheel and make a taper lock for it next.jonesie
« Last Edit: October 17, 2012, 02:27:05 PM by jonesie »
Offline mzt
Re: jonesie's simpson and shipson
« Reply #1 on: October 16, 2012, 07:50:26 AM »
You're way ahead of me on this build.
I'll take a seat in the front row and follow.
Marcello
This is a fitting job,
not a production job that can be measured in.
« Reply #2 on: October 16, 2012, 11:38:08 AM »
I'll sit next to Marcello if he doesn't mind and watch too.
Looks very interesting.
I did a quick search on 'simpson and shipson' but only came across a few hits on model forums (like ours!).
Are there any pics?
Offline Stilldrillin
« Reply #3 on: October 16, 2012, 11:44:51 AM »
Count me in too!  :ThumbsUp:
A pal has just bought a non runner......... "We" are going to fix it...... I'm told!    :help:
David D
David.
Offline mzt
« Reply #4 on: October 16, 2012, 12:06:40 PM »
Carl,
there's a typo in the name, that's "Simpson and Shipton"
If You're looking for pictures of the real one, I found none.
Stew's build was well documented on MadModder.
http://madmodder.net/index.php/topic,6485.0.html
http://madmodder.net/index.php/topic,7161.0.html?PHPSESSID=etfqj2jjq7g21pcigikbqhu4h4
Marcello
« Reply #5 on: October 16, 2012, 12:12:44 PM »
Thanks Marcello!
I remember seeing that build. Beautiful job too.
That's going to be a nice looking engine jonesie.
Offline jonesie
« Reply #6 on: October 16, 2012, 11:14:54 PM »
sorry about the typo thanks marcello for correcting.there are a lot of parts that are 2 off so will be a little slower build. hope mine looks as good as stews when i am done ,he did a real fine job. jonesie
Offline sbwhart
  • Live Long and Prosper
« Reply #7 on: October 17, 2012, 06:59:42 AM »
Are there any pics?
Carl
Some info on the engine her including animation
http://www.douglas-self.com/MUSEUM/POWER/rotaryengines/rotaryeng3.htm
Stew
Offline jonesie
Re: jonesie's simpson and shipton
« Reply #8 on: October 17, 2012, 02:25:37 PM »
thanks for the link stew, i  fixed spelling in the subject. i think this is quite i neat looking engine and design looking forward to getting it finished, hoping not to get side tracked.need to start painting some of my builds,hoping to do with my new airbrush.  jonesie
« Reply #9 on: October 17, 2012, 11:12:16 PM »
Thanks also Stew for the link.
jonesie...that's going to be interesting!
Offline sbwhart
« Reply #10 on: October 18, 2012, 08:11:14 AM »
Jonesie
You're getting to a couple of critical features.
Connecting rods:- the hole centres on all four rods must all be the same, the exact size is not that inportant but they must all be the same.
Bearings:- you must get the centre height of the bearings correct, measure the height of the crank shaft centre from the base plate and make the bearing centre height the same, I had to make small adjustment to the height by shimming under the bearings with ally baking sheet, if you get it wrong it just wont turn over it will be tight at top or bottom dead centre depending which way its out.
Stew
Offline jonesie
« Reply #11 on: October 18, 2012, 02:52:56 PM »
thanks for the heads-up stew,   i will make sure the holes are the same and will make sure my bearing heights are right.this is a nice design and is a real fun build, think the curved spooks on flywheel will look good, the casting is first class,got it from martin model and pattern.i have used his casting before and they all have been first class. thanks again. just made a note on prints for these heads up so i do not  forget. jonesie
Offline jonesie
« Reply #12 on: January 17, 2013, 04:09:51 PM »
well i have the parts all made  will post a pic real soon. this is a question for stew or anyone else who has timed one of there.stew i have the drawing that you sent me as far as the timing, but not being real  well versed on timing of steam engines. i did get the popcorn timed and running good but now i am stuck.what i am asking is if you have any more pics or drawings you could sent me or post on here as to the position of all the parts on the piston rod and then down to the rods on the steam chest.also having trouble with old and stiff fingers in tiny spaces but i will over come that on my own.thanks stew or anyone else with help or drawings. just hpoe i can get it to run as good as yours stew, it is looking good . pics coming soon. thanks jonesie
Offline sbwhart
« Reply #13 on: January 17, 2013, 08:18:06 PM »
Hi Jonesie
Pleased you've made good progress.
attached pdf drawing of timing geometry
First with the cylinder at top dead centre you have to set the crank arms at 90 deg to each other, on either side of the piston rod and the crank shaft so that connecting rods are working in parallel, so that the engine turns over smoothly, this is not easy to do, patience is the thing her.
You can see this in the vid
<iframe width="420" height="315" src="<a href="https://www.youtube.com/watch?v=kxpAIlInObk" target="_blank">http://www.youtube.com/watch?v=kxpAIlInObk</a> frameborder="0" allowfullscreen></iframe>
With the crank arms set and the engine turning over nice and free, you can now set the piston valve, this is easy to do, with the cylinder on top dead centre slacken off the eccentric and turn it in the direction of rotation and watch for the piston valve to start to apear in the exhaust port when you see about 0.5mm of it tighten the eccentric grub screw, and the timing should be set.
Hope that makes sence:- looking forward to your completed pictures.
Stew
« Last Edit: January 17, 2013, 08:42:04 PM by sbwhart »
Offline jonesie
« Reply #14 on: January 17, 2013, 11:24:19 PM »
thanks stew i will give this a try,will try to post some more pics also.thanks again jonesie
