Author Topic: Elmer's 36 Reversing Wobbler - 2x - Imperial - Mike's 2nd engine  (Read 16293 times)
Re: Elmer's 36 Reversing Wobbler - 2x - Imperial - Mike's 2nd engine
« Reply #120 on: September 23, 2018, 05:30:13 PM »
Very nicely done! Excellent runner, and great finish on the parts. Love the sound too!
 :whoohoo:
« Reply #121 on: September 23, 2018, 05:32:22 PM »
A fine result Mike. You should be proud of that one and how well it runs.
« Reply #122 on: September 23, 2018, 05:38:57 PM »
Hello Mike,
Boy that engine does have a great sound, like a train, good job.
« Reply #123 on: September 23, 2018, 06:03:33 PM »
Nice work, Mike!
It's so exciting when you get the to run!
Congratulations on an great runner!
« Reply #124 on: September 23, 2018, 07:04:24 PM »
Awesome runner and very nice work Mike you should be proud.
Offline AOG
« Reply #125 on: September 23, 2018, 07:37:30 PM »
It looks and runs great. So what’s next on your build list?
Tony
Offline mikehinz
« Reply #126 on: September 23, 2018, 07:47:11 PM »
Tony
Ahhh, a most interesting question!   I'd been thinking about that very thing for the past few days.  I believe it's going to be Stew Hart's Horizontal Potty Mill Engine.  I greatly prefer horizontal engines and that would be a good first one, I think.  I think I'm going to try purchase a cast flywheel and use scale fasteners from American Modeling to get a bit of a 'realistic' look.
First though, I need to do a bit of work in my shop.  I have a DRO kit for my lathe that i want to install and I need to make a few misc tools.  I want to make some tailstock die holders and a 'pump-center' for my lathe.  I also have a 3 jaw chuck that needs to be rebuilt and a 6 jaw chuck that needs to have the jaws ground.   So, I hope to start a new build in a couple of weeks.
Thanks for watching this build!
Mike.
MIke
Wichita, KS, USA
toolznthings
« Reply #127 on: September 23, 2018, 08:23:03 PM »
Super cool !! Nice job for sure !  :ThumbsUp:
Are you going to share plans ?
Thanks !
Brian
Offline mikehinz
« Reply #128 on: September 23, 2018, 08:30:45 PM »
Thanks !
Brian
Yes, I will share the drawings and the Fusion 360 model.  I'm making the last few corrections to the drawings and should finish that today or tomorrow and will post them.  The drawings will be accurate and you'll be able to build from them, but what will be missing is the tolerancing, so some judgement will be required.  For example, I have a .25 shaft going into a .250 hole.  That obviously won't work, but it will be up to the builder to figure out if the shaft should be made under or the hole made over and by how much.   I think the biggest value in these plans is that the air passage layouts are very clear, at least to me!  And the air admission passages into the cylinder are shown accurately.  Elmer's original drawings used a jig and the dimensioning was missing for these critical points.  Just fyi, it turns out that the cylinder oscillates 11.5 degrees from vertical so 23 degrees total.  Odd, but true!
FYI.
Mike.
MIke
Wichita, KS, USA
Offline propforward
  • MN, USA
« Reply #129 on: September 23, 2018, 08:46:23 PM »
Nice job Mike, that's a lovely engine. It's a small aspect, but I especially like the fillet of braze you ended up with after turning it clean - looks really excellent!
Beautiful runner, very impressive.
Forging ahead regardless.
« Reply #130 on: September 23, 2018, 10:52:44 PM »
Really nice Mike. I like the finish also and it’s a sweet runner for sure  :ThumbsUp: :ThumbsUp:
Whiskey
Offline kev
  • Portsmouth UK
« Reply #131 on: September 23, 2018, 11:04:19 PM »
nice one and finely finished surfaces, one for the mantel shelf:)
Offline Larry
  • Atlanta, GA
« Reply #132 on: September 24, 2018, 05:32:39 AM »
You did this in record time. Great finish and sound. Congratulations !
Offline mikehinz
« Reply #133 on: September 24, 2018, 10:40:24 PM »
I've just posted links to the Fusion 360 model and the PDF of the drawing set for this build.  They should be very close to correct as I made all the revisions/corrections that I found during the build process.  Additionally I've gone over the drawings pretty carefully to make sure that they are easy to understand and are as clear as possible.
Good luck if anyone decides to build this engine!
Mike.
MIke
Wichita, KS, USA
