What's the best way to center rectangular pieces with off-center hole in a 4 jaw chuck? As above, what i attempted was to put in center holes at the required locations using the mill and then using a DTI, make that center hole run true. This seems very slow to me. I'm sure some of it was lack of familiarity with the process but using a DTI in a very small hole like that is tedious. It's hard to get it close to on axis and generally a pain!
Mike - same here - last two pictures only.The cylinder looks great though!gary
Yep. All pictures there and they look great!
All, I have a quick technique question:What's the best way to center rectangular pieces with off-center hole in a 4 jaw chuck? As above, what i attempted was to put in center holes at the required locations using the mill and then using a DTI, make that center hole run true. This seems very slow to me. I'm sure some of it was lack of familiarity with the process but using a DTI in a very small hole like that is tedious. It's hard to get it close to on axis and generally a pain! So, any input regarding a better process is greatly fully appreciated!
The method that works best for me is the use of what machinists term a "pump center".
