Nice work on the silver soldering!I use Oxy-Acetylene for silver soldering. With steel, you can be a bit more direct with the heat, but with brass, you have to be really careful or you melt the brass! I've found that you don't get the parts hot enough, fast enough, they starts to turn all black and sooty on me. I'm no expert though. Sounds like you've done a lot more work with the torch than I have!Pretty nice looking joint to me though. Should look great when its cleaned up!Kim
hi mike also when you put the part back in the lathe after the brazing you could help hold and center it by using your live center in the tail stock just run it in to hold it and help center,can always remove later to do work on the end. i do this at work at and also have a bullnose center for bigger stuff. parts are looking good
