Author Topic: Hello from Finland  (Read 2631 times)
Offline Baner
  • Cowaramup, Western Australia
Re: Hello from Finland
« Reply #15 on: August 17, 2018, 04:52:48 PM »
I use Flickr and embed my photos so I'm not familiar with attaching photos directly. I don't think you get preview images on this forum when you attach photos, as you would on other forums. As Zee said the  photos can only go after the text. You cannot attach a photo and then write something after it. Not sure if that's what's going on. Can you try a test image in this thread? I'll try it myself too.
Dave.
(Edit) There's no preview images but they show up when you post. Here's a screen shot of what you see for photo attachments on the draft page:
« Last Edit: August 17, 2018, 04:57:30 PM by Baner »
« Reply #16 on: August 17, 2018, 06:45:24 PM »
What bothers me is that Moxis said he was able to see the size of the attachment.
That makes me think 'something' worked.
I've seen after posting that my image doesn't immediately show up...but the little text (that gives the size and number of times viewed) under the image does.
If I wait a bit, or leave and come back, then the image is there.
Where did you notice the size of the attachment?
BTW Moxis, clicking on that little text should cause a download of the image.
I use Chrome and the download tab shows at the bottom.
When I click on that, another window with the image shows up.
I did that with Thomas' 1st image and noticed it took a while to display.
Offline Moxis
« Reply #17 on: August 18, 2018, 08:06:44 AM »
Thanks again guys for your help. I try to add a photo or two, let`s see if it works. It may be that it takes a while before it shows here, so I try to be patient.
Edit: Aa it worked when I hit the Post button. So now I think I can add photos, hurraa :cheers:
« Reply #18 on: August 18, 2018, 08:47:05 AM »
Hello again Moxis,
OK, your photo shows now, you are good to go.
Have a great day,
