Author Topic: ED Bee Con Rod  (Read 1993 times)
Offline Allen Smithee
  • Mordor, Middle Earth
ED Bee Con Rod
« on: July 30, 2018, 04:02:32 PM »
A friend of mine has come by an ED Bee which he'd quite like to use in a suitable radio-assist vintage model. The engine seems to be in pretty good nick except that it has a broken con rod. My normal sources have drawn a blank on this (including Alan Greenfield), so I wondered if anyone here had a spare one they don't need? The engine is a mk2 Bee, so it has the Aluminium rod rather than the case-hardened steel one. As far as I know the ED Cadet rod was probably the same as well. SO if anyone has one could they possibly get in touch?
Failing that - given that he wants to use it as a runner rather than a museum piece, and a basic rod for a small, low-power diesel isn't exactly the most complex job in the world, does anyone have a drawing or even just the principle dimensions? I guess I could probably get by with the big/little-end bore sizes, the distance between centres and the thickness...
TIA,
AS
Online b.lindsey
Re: ED Bee Con Rod
« Reply #1 on: July 30, 2018, 04:09:41 PM »
Is the broken con rod mangled beyond taking measurements from it?
Re: ED Bee Con Rod
« Reply #2 on: July 30, 2018, 06:25:08 PM »
No, but half of it is missing!
AS
Re: ED Bee Con Rod
« Reply #3 on: July 30, 2018, 06:35:35 PM »
Ask on Adrian's blog http://adriansmodelaeroengines.com/wordpress/ to see if someone knows the correct length and then it should be easy enough to make as it is only a simple steel rod
  • S°ften - Denmark
Re: ED Bee Con Rod
« Reply #4 on: July 30, 2018, 09:08:53 PM »
I had the notion to ask Ron Chernich before he died about collecting such data for future repairs .... maybe Adrian would be interested.
I do have a number of in-complete production engines where pistons an rods are missing, so beside rod length, it would be nice to have piston height and pin position (distance from crown). I have made an excel file on all my engines and do fill in as I get info - or disassemble one of the complete ones.
- But I do not have any info on the ED Bee - sorry.
Re: ED Bee Con Rod
« Reply #5 on: July 30, 2018, 10:52:53 PM »
The original was forged aluminium, but I suspect one made from bar-stock dural will be adequate. But yes, it's not a hard thing to make.
AS
Re: ED Bee Con Rod
« Reply #6 on: August 05, 2018, 04:08:10 PM »
Eric says he has one for you  ;)
Re: ED Bee Con Rod
« Reply #7 on: August 05, 2018, 04:29:24 PM »
Ace! I'll give him a call!
AS
Re: ED Bee Con Rod
« Reply #8 on: August 14, 2018, 11:26:00 AM »
Many thanks to Eric, and others for the help. My friend is now happy, and sent me this to prove it:
AS
Re: ED Bee Con Rod
« Reply #9 on: August 14, 2018, 11:28:30 AM »
 8)
