Author Topic: Getting a good finish  (Read 4290 times)
Offline Stuart
  • Tilchestune UK
« on: October 15, 2012, 04:15:07 PM »
First don't shot the messenger
I hade a job in the lathe today which involved boring a hole 0.75 inches dia in a piece of 1 inch square stock 3 inches deep through not blind
I was using  one of the tipped boring bars that are common in the merchants store  ( Glanze omega at el )  my HSS bars are either to short or to big
as I stated with a 0.5 inch drill the boring bar was small and well extended the finish was terrible look like I had used a rusty nail ,
so  on when  a new tip the one they sell for steel no improvement tried it fast, tried it slow, tried it dry, tried it with cutting oil  still a very bad surface , but as the finish size was getting near desperate measures was call for.
the hole dis. still required the middle size bar  so a quick sort in the tip draw and I found some of those tips they sell for non ferrous metals nice and sharp with a good rake ( supplied from the  dunstable outfit )
so one it went the cutter it just hissed and the finish was superb, by this time I could get in with the larger bar with the NON ferrous tip on the results were the same a good ridge free smooth finish in the bore
now I realise that these tips would not hold up for any heavy cuts but for finish work they work fine on Steel
I do not Know the grade but it aint EN1A  it must be a form of GGQ   ( Good ? General Quality ) unmachinium
again its one of the thing that goes against the book but it got me out of a mess today
may be worth a try next time I have some nasty lumpy steel to turn
Bogstandard
Re: Getting a good finish
« Reply #1 on: October 15, 2012, 08:31:11 PM »
Stuart,
If you have a mill boring head and can hold the part OK, I find that boring in the mill gives a far superior finish and size just using the crappy brazed tipped boring sets you can buy.
If I want ultimate finishes and sizes, then I use the HSS 'German' types of boring bars.
Top few on this page
http://rdgtools.co.uk/acatalog/TOOL_S_FOR_BORING_HEADS.html
Offline Stuart
  • Tilchestune UK
« Reply #2 on: October 16, 2012, 08:19:13 AM »
thanks John for the info
Arbalest
« Reply #3 on: October 16, 2012, 10:27:19 AM »
Yes, thanks John. Not seen those type before.
Bogstandard
« Reply #4 on: October 16, 2012, 11:52:11 AM »
The 'German' types of boring bar are the type that you can very easily make yourself using silver steel, but I am a great believer in not making tooling if it is available commercially much cheaper than it would cost me in time and materials to make them myself.
If I needed more robust ones, I would have to make them myself, as the ones I have seen available at reasonable prices are only in the smaller sizes.
