Author Topic: Machine Oilers  (Read 951 times)
Online steamer
Machine Oilers
« on: July 22, 2018, 12:25:10 AM »
OK guys and gals.   My Aciera has "Grease" fittings for oil, both on the spindle and the ways and gear box.
I've modified some grease guns to inject oil, but they leak like a sieve.    Time to get some real oil guns!
who sells them!..and where?
Re: Machine Oilers
« Reply #1 on: July 22, 2018, 12:34:36 AM »
Are these the fittings with the little spring loaded balls Dave?
Online steamer
Re: Machine Oilers
« Reply #2 on: July 22, 2018, 12:44:51 AM »
Yup....Zerk style fittings....but they're not for grease...very typical European set up.
Mobil #6 DTE spindle oil
Vactra #2 otherwise.
Offline deltatango
Re: Machine Oilers
« Reply #3 on: July 22, 2018, 05:37:30 AM »
Hi Dave,
In my remote corner of the world even buying a decent oil can is hard. For the oilers on my F3 I made a little brass adapter for an existing oil can with a recess for an O ring to make a seal on the nipple (see pictures attached). This arrangement isn't ideal for oilers that point straight up but there aren't many of those.
Hope this helps!
David
Don't die wondering!
Offline Steamer5
  • The "Naki" New Zealand
Re: Machine Oilers
« Reply #4 on: July 22, 2018, 07:43:58 AM »
Hi Dave,
Now thatís cunning!
Take it that the o ring is just a neat push fit?
Cheers Kerrin
Offline deltatango
Re: Machine Oilers
« Reply #5 on: July 22, 2018, 07:58:28 AM »
Hi Kerrin,
Yes, if you squeeze the trigger without pushing the nozzle on to an oiler then the O ring goes flying. Just have to be careful...
David
Offline Steamer5
Re: Machine Oilers
« Reply #6 on: July 22, 2018, 08:02:34 AM »
Thanks Dave
Cheers Kerrin
Online steamer
Re: Machine Oilers
« Reply #7 on: July 22, 2018, 11:43:25 AM »
Hey Dave,
Thanks for that!   What I could do pretty easily ...I think....is convert a conventional oil can with a flexible kneck to hold the grease gut tip.    I'll look into doing that.
Online Dave Otto
Re: Machine Oilers
« Reply #8 on: July 22, 2018, 04:28:23 PM »
I use the one that came with my lathe, similar to this only larger.
https://www.amazon.com/Push-Type-Oil-Hydraulic-Tip/dp/B01N0AR9L0
It does a pretty good job of pumping oil into the fittings. Before I got my lathe someone had removed all the oil fittings to keep people form pumping grease into the ways. I replaced them with standard Zerk fittings which work ok, but probably not as well as the original oil fittings. Do you know if the oil fittings have a different shape than a standard grease Zerk?
Online steamer
Re: Machine Oilers
« Reply #9 on: July 22, 2018, 06:31:07 PM »
A standard zerk tip fits on the fittings.   Thats all I know
2 of those oil guns should work just fine....ill save my sheckles....
