Author Topic: My Little Hit Engine from bar stock NEW update with Brushless Beta Max Stator  (Read 2842 times)
Offline dwulfe
This was inspired by the Tiny IC posts and various others especially Rudydubya's.
It has 3" flywheels with a .5 inch bore by .75 inch stroke. It hand starts on Coleman camp fuel.
The valve springs are from retractable ball point pens. The gears where bought cheap (< $10) and modified.
It has cast iron piston and sleeve without rings. The crank is .25" with .188" rod journal.
Here is a video. It's running a bit rich but I like the slower speed. Notice how it picks up when I pull the draw tube out of the fuel.
I've been experimenting with a mixer. This video is the second variation. I have since found that I can lean it out by inserting a .015" wire in the .020" id draw tube (brass bushing stock for clock maker).  Not quite finished but getting close.
« Last Edit: September 08, 2020, 11:57:45 PM by dwulfe »
Re: My Little Hit Engine from bar stock (mostly)
« Reply #1 on: July 16, 2018, 09:57:50 PM »
Very nice a a good runner too. They are fun little engines for sure. Nicely done!!
« Reply #2 on: July 16, 2018, 09:58:53 PM »
Very nice little engine. I have a couple of similar hit and miss engines that are running Viton O-rings on the piston. The Viton gives amazing compression, but it also creates a lot of "drag" in the engine, so I have never been able to get them to hit and miss the way I'd like them to. If I ever build another hit and miss engine I will try and do it with a lapped piston and cylinder, no ring, and see how that works.---Brian
« Reply #3 on: July 16, 2018, 10:02:21 PM »
Beautiful little engine and a nice runner.
Have a great day,
Offline Sleddog
  • South East South Dakota, USA
« Reply #4 on: July 16, 2018, 10:31:53 PM »
Very nice! :ThumbsUp: Thanks for posting.
« Reply #5 on: July 16, 2018, 11:15:24 PM »
Beautiful job.  :ThumbsUp:
Offline propforward
  • MN, USA
« Reply #6 on: July 16, 2018, 11:39:58 PM »
Superb engine! Nicely done.
Offline 90LX_Notch
    • YouTube Channel
« Reply #7 on: July 17, 2018, 12:54:01 AM »
Nice!
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline rudydubya
  • Western Arkansas USA
« Reply #8 on: July 17, 2018, 08:20:08 AM »
Nicely done!  Looking forward to seeing it finalized.  Will you be showing us any build pictures?
Rudy
Offline dwulfe
« Reply #9 on: July 17, 2018, 01:08:48 PM »
Thanks Bill, Brian, Thomas, Sleddog, Zee, Propforward, and Bob for your comments.
Sorry Rudy, I didn't take any photos along the way. I would like to add a governor at some point but I need to finish the fuel system.
Brian, thank you for all your posts. I learned a lot from them. I had to make a 2nd piston for this one. I failed in my first attempt. I lapped the fresh off the lathe piston and sleeve with brasso on the first one. It was leaky. I could see fuel bubbling out from the back of the piston when I flooded it while attempting to get it started. I then spent an hour and half lapping the cylinder with a commercial lap and 320 grit. I took about 2.5 mils off. Went from .505 to .510. It took that much to get a uniform gray finish in the bore. Then I snuck up on the piston od using the sleeve as a gauge. Once the piston would wiggle in an few tenths of an inch I then parted off the blank and finished the other features. I then used brasso and oil to lap the two together until silky-smooth full stroke. Took a maybe a couple hours. It is a very good fit with enough compression to hand start.
Offline dwulfe
Re: My Little Hit Engine from bar stock (mostly) update
« Reply #10 on: September 01, 2018, 02:04:18 PM »
I added a C.Fellows type carb and a fuel tank.
Offline dwulfe
« Reply #11 on: September 01, 2018, 02:09:54 PM »
It runs to my liking now with the ignition timing slightly retarded and a silicone boot over the plug to prevent arcing.
I tried to count pops per 5 seconds and estimate about 400 rpm.
« Reply #12 on: September 01, 2018, 02:26:43 PM »
Sure has a sweet sound to it!! Even your shop buddy seems to like it  :)
« Reply #13 on: September 01, 2018, 02:45:21 PM »
Sounds great! Congrats!  :ThumbsUp:
Offline propforward
  • MN, USA
« Reply #14 on: September 01, 2018, 03:00:45 PM »
That's a gorgeous engine, runs and sounds superb. Good to have a shoppe dawg in there too!
