Author Topic: How do I select a rotary table?  (Read 9237 times)
Re: How do I select a rotary table?
« Reply #30 on: July 11, 2018, 06:32:17 PM »
You use a pin wrench to tighten the ring which holds the plate in place so it does not slip on the spindle.
A bit of round rod makes a very adjustable pin wrench and if often called a Tommy Bar. ;)
The spin indexer does have the advantage of being able to do any number that will divide into 360, but an indexer can only do spacings that divide into the number of holes for instance I doubt Jo's will give you a 10 hole spacing :) You can even rotate them to round over parts again can't do that with an indexer. Oh and my indexer takes ER32 with minimal overhang. Can't think why Jo gave it to me :LittleDevil:
« Last Edit: July 11, 2018, 06:36:45 PM by Jasonb »
« Reply #31 on: July 11, 2018, 06:57:41 PM »
Because 99% of the time all I want to do is index by 4 or 6 or on the odd occasion 8 and as fast as possible.
Not sure what You can even rotate them to round over parts again means.
ER32 has rather long minimum length which 5C does not..I cannot see the point in ER32 if you have 5C. As you can make do and mend is why you now have it  ::)
Offline Doc
  • USA ND
« Reply #32 on: July 11, 2018, 07:18:32 PM »
I seen some comments on this thread about needing an indexer,or rotary  to cut gear. I say not true a very simple way to cut gears is a -v- block and lid from a container. Here is a video of the process and will work for any number of teeth. Just saying.
<a href="https://www.youtube.com/watch?v=gKlFEVWEtuI" target="_blank">http://www.youtube.com/watch?v=gKlFEVWEtuI</a>
« Reply #33 on: July 11, 2018, 07:33:27 PM »
I thought being newly retired means you have lots of spare money and time :noidea:
As you are approaching retirement yourself, methinks you'd best review your future plans right away.  :hammerbash:
More time...yes. Lots of spare money...well...everyone of us has a different definition of 'lots'.  :Lol:
Jason came to my rescue once again. A Tommy Bar. I happened to have one and it fit!
Part of my reason for asking these questions is that I have a cylinder to make that is partly round and two flats.
Starts from a rectangular block of material.
I wasn't sure if the spindexer could be used (possible if the angles are right) but I'm thinking on two other methods...
1) Kozo used a method where he drove a lathe carriage back and forth to shave off the curved sides. Then filed to final shape.
2) I've seen others use a rotary table in a vertical position and then mill and rotate to get the curve.
I'm leaning towards the 2nd method (which probably means I need to get a chuck for the RT and make up a mandrel).
Sigh. More money. Time to play the game of what budget item I can steal from.
« Reply #34 on: July 11, 2018, 07:40:41 PM »
If you're starting with rectangular stock, just clamp a machinist's vise to the RT.
« Reply #35 on: July 11, 2018, 08:02:08 PM »
Other way is to clamp in mill vise with a rod through the bore as a spacer on top of the jaws, use end mill like he uses the lathe tool, been using that to do bearing caps recently.
« Reply #36 on: July 11, 2018, 08:16:33 PM »
So here’s Cletus’ POV. Retirement; would love to, I think. However, at 58 and a tool spending habit that ranks up there with the Kardashian’s makeup bills  :lolb:, I keep on getting my old bum up each morning and trudging onwards  :old:. On the rotary table: I think the one that you’ve shown that you already have, should work fine. The dividing plates do come in handy for gear cutting. Granted, you can do the maths and arrive at the number of degrees, minutes, and seconds required for each tooth, but, it’s just a lot easier, in my eyes, to do it with plates and sector arms. Dividing heads are great and have thought about getting some AMEX points with the purchase of one, but, my rotary table works vertically and I have dividing plates; so what would I be gaining but the points  :shrug: My table has a MT 2 taper in the center hole and I made an arbor to take the chucks from my old South Bend. I have a spindexer and the only thing I’ve ever used it for was cylindrical grinding. If I were buying again today, my biggest concern would be rigidity. I want something robust enough that I don’t feel the cutter teeth biting as I turn the dial. If you do decide to upgrade, I’d look hard at the Shars 6” with chuck and add the plates and tailstock. Ok, I’m done babbling now.
Cletus
« Reply #37 on: July 11, 2018, 08:22:19 PM »
Jo, this was rounded in the spin indexer, leave the pin out and rotate after taking the majority off with faceted cuts. Rather than having to buy lots of tools Zee can use what he has, same applies to collets, I expect he has ER so can use them rather than having to buy5C and remember I only went for 5C as you offered a cheap chuck.
Zee for your D section cylinder you don't need anything more than a mill vice, a bit of bar and a file. just put teh bar through teh cylinder bore, rest on te vice jaws and take several cuts by rotating teh part a few degrees at a time then finish with a file
No need to use a rotary table but it can be handy for more complex cylinders such as this
Better to learn to make the most of what you have rather than go out buying loads of stuff that may hardly get used though having a rotary table does usually get you free entry to teh "No Castings required" club. Couple I have "cast" in the last week or so.
« Last Edit: July 11, 2018, 08:33:52 PM by Jasonb »
« Reply #38 on: July 11, 2018, 08:24:34 PM »
This will continue on my popcorn thread (someday) but...
Attached is a drawing of the cylinder.
@Marv...I'm not sure what you mean or how to hold the part. In any case, my machinist vise is too large or the RT too small.
@Chris...Good idea although I like the idea of the RT telling me where the part is. As I think about it though...there are probably other ways to do it. Use the straight edges as stops?
I'm thinking 1st job is the cylinder bore. Then go to the mill for the ports and various holes. Last bit is machining the curve.
Just saw your post Eric. I took a look at the Shars 6". Jo mentioned to avoid 3 slots but didn't say why.
Just saw your post Jason. I have 5C. No ER at all. As for filing...see attachment. I'm concerned about the point where the curve comes into a flat (near the bottom). Your photo also makes me think I can use the spindexer. The bore is 1/2" and I have a 5C for that.
« Reply #39 on: July 11, 2018, 08:24:53 PM »
JBWelder: :headscratch: I read 5C on that collet.
« Reply #40 on: July 11, 2018, 08:41:46 PM »
You queried how to do curved work not what to hold it with, I use what suits the job and as that was a bit of 1" bar I could hardly use a ER32. Also as I don't have a full metric set of 5C the ER get used for the ones I don't have.
Zee from your drawing any of the methods would work, in the vice, in the spinner or with the R/T, this would be a fairly similar setup for the R/T where the curve meets a flat surface
http://www.modelenginemaker.com/index.php/topic,5820.msg115741.html#msg115741
nearest pic I could find to what you want to do using the spinner
« Last Edit: July 11, 2018, 08:57:33 PM by Jasonb »
« Reply #41 on: July 11, 2018, 08:49:40 PM »
Standing it vertically in a vice won't give you that crisp joint where the curve meets the flat you will get a fillet the size of the cutter radius.
Also you would need a long series cutter as your cylinder looks to be about 1.5 long
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #42 on: July 11, 2018, 09:15:58 PM »
Jason, I was looking at the cylinder you cut (in post no 37 - 4th pic) do you fancy doing a duffers guide to cutting cylinders from solid ? I'd be interested to see how to go about it and I bet there's a lot more members who also like to see  :)
« Reply #43 on: July 11, 2018, 09:21:29 PM »
Thats why you put it horizontally in the vise, use a rod down the bore as a hieght spacer, and make a series of cuts with the bottom of the end mill, rotating the part in the vise between cuts.
« Reply #44 on: July 11, 2018, 09:51:07 PM »
Zee--One more important thing to consider is the weight of the rotary table. I'm a pretty strong guy, and it's all I can do to lift my 6" rotary table with chuck attached from the shelf where it normally lives over and onto the mill table. I see that some people use a hoist and sling to lift larger rotary tables, but that becomes a pretty big inconvenience.---Brian
