Hay Dave, by fab do you mean fabrication technique/method?
I'll answer that question any way. Sorry I didn't take any photos it all happened pretty quick.
To make the pattern into its final shape was more of an evolutionary process than detailed design.
It is a bit of a rough-n-ready, to be honest
Each side was built separately and the first side was just duplicated.
I took a sheet of 16mm mdf and cut out a piece that would fit across two T slots of my mill table.
Then took two pieces about 40mm wide by 125mm long superglued them together banged in a nail or two to hold it all in place so I could shape it on the linisher putting a draft taper on all sides by eye.
after sealing and sanding ready to make a mold I thought I want to use a cotter pin type spindle clamp, but there is probably not enough room along side the spindle to do that. The solution was to cut 4 off 6mm mdf pieces and glue them each side of each pattern half - that explains the interesting shape.
The filleting is just a plaster type wood filler. then the whole thing was sealed again and the mold made.
The gating system was totally inadequate for such a huge chunk of a casting so there is quite a dip in the casting on the side facing the chuck but I was able to trim it square while it as bolted to the mill table.
The next bit was to center up the spindle blank in the four jaw and centre drill it ready for a later operation.
Then flip it over and center it up again. Then drill and bore a 15mm core almost to the centre hole at the other end.
Adjust the compound slide to bore the 8 deg taper for an ER Collet. I would have liked to use ER32 but the blank was less than the 40mm needed to cut the nut thread. (only 38mm
ER25 will be OK and the nut thread is only 32x1.5mm.
This is where we are at now. Waiting for an ER25 nut
Thanks for dropping in.
Bez
