Author Topic: Maudslay Marine Engine  (Read 32129 times)
Re: Maudslay Marine Engine
« Reply #135 on: July 24, 2018, 05:18:28 AM »
That is a LOT of work you put into those frames, Chuck, but they sure look nice!  :ThumbsUp:
« Reply #136 on: July 24, 2018, 12:27:17 PM »
Great fabrication and such an elegant look. I can't wait to see this one finished. With that large flywheel it ought to tick over gracefully.
« Reply #137 on: July 24, 2018, 12:48:19 PM »
Clever way to use the tubing rather than solid round brass. The final result is beautiful Chuck.
Offline cfellows
« Reply #138 on: July 25, 2018, 04:05:20 AM »
Today I got the bearing blocks cut out.  The smaller ones are for the crankshaft and the larger ones are for cylinder pivot shaft.
The Cylinder pivot blocks will be split horizontally and held together with screws while the crankshaft blocks will remain whole.
Chuck
Offline cfellows
« Reply #139 on: July 26, 2018, 03:04:20 AM »
Just about done with the frame sides.  Still have to bore out the crankshaft bearing blocks and do a bit more polishing.
Online sco
« Reply #140 on: July 26, 2018, 06:21:55 AM »
The originals were works of art, so are yours!
Great work Chuck,
Simon.
Ars longa, vita brevis.
Offline cfellows
« Reply #141 on: July 27, 2018, 02:46:43 AM »
Thanks, Simon.
I had to do some remedial work today.  One of the frames was about .030" taller than the other.   :(  So, I unsoldered the top pieces, shortened the tubes on either size, and re-soldered it.  Luckily it went back together without mishap and cleanup wasn't too bad.
I made the 4 screws in the middle from 3/16" 12L14 Hex stock.  They are threaded 6-32 and will hold the caps on the bearing blocks.  I'm planning to go through all the top pieces to reinforce the solder joints.
Offline cfellows
« Reply #142 on: July 27, 2018, 10:48:53 PM »
Had a pretty productive day today.   I finally got it to a stage where you can get a pretty good idea of what it's going to look like...
My confidence is growing that I'll actually finish this engine.   :DrinkPint:
Chuck
« Reply #143 on: July 27, 2018, 10:59:22 PM »
WOW  :whoohoo:
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #144 on: July 27, 2018, 11:09:56 PM »
That really is going to be one elegant looking engine once done Chuck :ThumbsUp: :ThumbsUp: - you have my undivided attention for sure :)
Lovely work so far, keep it coming
Regards - Tug
« Reply #145 on: July 28, 2018, 12:52:23 AM »
Just wonderful proportions, very well done!
 :popcorn: :popcorn: :popcorn:
« Reply #146 on: July 28, 2018, 01:22:59 AM »
That is one impressive engine, Chuck! Beautiful.  :praise2:
« Reply #147 on: July 28, 2018, 01:40:03 AM »
Awesome Chuck. That's a real beauty.  :ThumbsUp:
« Reply #148 on: July 28, 2018, 01:48:48 AM »
I can only repeat what others have said. Just a lovely engine in all respects.
Offline Steamer5
  • The "Naki" New Zealand
« Reply #149 on: July 28, 2018, 06:59:05 AM »
Hi Chuck,
 Very very nice!
Cheers Kerrin
