Author Topic: Division Master still around?  (Read 2929 times)
« on: June 30, 2018, 08:43:04 PM »
Looking to convert a Sherline table to CNC indexer.    Division master was one kit out there.    Any others?
Re: Division Master still around?
« Reply #1 on: June 30, 2018, 09:09:40 PM »
Dave, I assume you are talking about the Sherline rotary table. You might check the Sherline site. There control box for the CNC RT will allow entry of the number of divisions you want and them step them off. Wasn't sure if you were looking for a whole new system or to convert a manual RT. This may be possible through Sherline as well.
« Reply #2 on: June 30, 2018, 09:59:07 PM »
I have the table already, so im looking for a kit to convert it.   Didnt know Sherline did  conversion kit... ill look
Thanks
« Reply #3 on: June 30, 2018, 10:10:32 PM »
Nope....no conversion kit for the manual.....you can get a CNC ready, or a full system, but not what I'm looking fore
Ron Ginger,,,,any advice?
« Reply #4 on: June 30, 2018, 10:50:11 PM »
Ok , wasn't sure exactly what you were looking for. Hope you find it.
Offline cwelkie
« Reply #5 on: July 01, 2018, 12:21:41 AM »
This may be an option for you Dave, depending on how deep you want to get into fabricating a solution:
http://www.worldofward.com/rotarycontroller/
There is a ready-made option for the controller board and display and they source a keyboard as well.  You'll still need to do an enclosure and source a stepper motor and matching driver.
I've no affiliation other than being a happy user of this controller after building one from parts to drive my 6" table.  It works as advertised and did so "right off the bat".
Charlie
« Reply #6 on: July 01, 2018, 03:22:10 AM »
Thanks for that Charlie!   Ill check it out!
Online Steamer5
  • The "Naki" New Zealand
« Reply #7 on: July 01, 2018, 04:59:29 AM »
Hi Dave,
 Plus one on Quackers...aka Wonderful World of Ward....RT controller. Brought the finished board, put it together & it works great!
Here’s mine.
Cheers Kerrin
Offline muddled engineer
« Reply #8 on: July 01, 2018, 08:26:00 AM »
Offline Noitoen
  • Setúbal - Portugal
« Reply #9 on: July 01, 2018, 09:12:20 AM »
Charlie
I bild one myself an works great. Just the other day used it in continuous mode to "turn" on the mill, a bearing recess on a disc brake adapter plate for my 4x4
Offline Stuart
  • Tilchestune UK
« Reply #10 on: July 01, 2018, 10:39:30 AM »
Try here
They have taken over a good while ago
http://medw.co.uk/wiki/index.php?page=DivisionMaster&hc1=0
Offline RonGinger
  • Boothbay Maine USA
    • Pleasant Cove Models
« Reply #11 on: July 01, 2018, 01:37:22 PM »
There i s a very active thread over on https://www.homemodelenginemachinist.com/threads/arduino-rotary-table-for-dummies.26744/page-9#post-308995. This one uses Arduino, which is an extremely well supported micro controller. It should be a lot less expensive than Division Master or the Sherline  controller.
« Reply #12 on: July 01, 2018, 02:31:57 PM »
Thanks Ron, Unfortunately, or fortunately....depending on your view point, I'm banned for life over there.  From what I can see, the electronics seem good, and I like the Arduino approach, but I'm looking for something a bit more industrial in the hardware department.   I can draw that part up I suppose, but I'm really not into building up electronics.    "Plugs right in" is what I'm looking for from the control side preferably.
Offline craynerd
    • www.raynerd.co.uk
« Reply #13 on: July 06, 2018, 12:25:24 AM »
Dave, I’ve had numerous Kwackers , World of Ward controllers over the past 10 years and they are great. I’m currently making one up now (just got back from the workshop!) for my Cowells lathe.
Steve is a great guy, sells them for I think £45 made and ready to run! You then just need a keypad, driver and motor and you are ready to go!
Wiring is simple and no hassle. If you are integrested, I can make a little video of wiring one up to show what you get from him and how you connect the rest of it up? No worries if you don’t think this would help.
Offline craynerd
    • www.raynerd.co.uk
« Reply #14 on: July 06, 2018, 12:27:20 AM »
...just to add, his divider is sold in parts as an electronics project or fully built...so if you buy the built version, it lieterally is just ‘plug right in’ when it comes to the rest of the parts I mentioned.
