Author Topic: Valve Packing material source?  (Read 1145 times)
Offline Reggleston
« on: June 17, 2018, 04:09:27 PM »
Anyone know where I can purchase a small quantity of Valve Packing Material, US or elsewhere?
Offline GordonL
Re: Valve Packing material source?
« Reply #1 on: June 17, 2018, 05:12:27 PM »
Most any place which sells plumbing supplies. Home Depot. Lowes, local hardware store etc
« Reply #2 on: June 17, 2018, 06:58:54 PM »
What I have found at the big box stores in the US is a round extruded type material usually imported and not that good IMHO. For braided, Teflon impregnated packing seal material down to 1/8" square check McMaster. If you need something smaller you can always unbraid it as well.
toolznthings
« Reply #3 on: June 17, 2018, 07:27:23 PM »
Look for graphite packing string for faucets. Use to come in generic faucet repair kits. Big box stores may have it if still made.
« Reply #4 on: June 18, 2018, 01:15:22 AM »
Not sure if we are talking about the same thing here, but for packing glands on the end of steam cylinders where the rod exits, I use plumbers Teflon tape. Tear off a piece about 3 or 4 inches long and roll it back and forth between your thumb and finger. It will become a "rope" which then works great for packing glands.
Online Dan Rowe
  • Dripping Springs TX USA
« Reply #6 on: June 18, 2018, 03:37:52 PM »
The stuff I like to use is round Teflon valve stem packing. You can split it along its length to make smaller sections like string cheese.
https://www.newegg.com/Product/Product.aspx?Item=2ZY-007H-002D3
Dan
ShaylocoDan
