Author Topic: High shear turning tool  (Read 1436 times)
Offline pgp001
  • West Yorkshire - UK
Re: High shear turning tool
« Reply #15 on: June 12, 2018, 07:38:15 PM »
You can use your diamond toolholder from Eccentric Engineering as a shear tool as well, just turn the toolbit 90. See video below at around 4 minutes in.
I use a shear tool on the shaping machine as well, it leaves a superb finish.
Phil
« Reply #16 on: June 13, 2018, 12:06:52 AM »
That Diamond tool is really nice...
I went out to the shop and whipped up Ians' version with the round cutter. There was a lot less grinding to get the shape and I ground the face and end on the flat of the wheel so it would be easier to hone. I'm impressed. Thanks Ian!!
