Author Topic: Bill's Shop Renovation  (Read 91526 times)
Re: Bill's Shop Renovation
« Reply #555 on: January 30, 2019, 09:41:45 PM »
Yes    slapped is the right term..... :hellno:
« Reply #556 on: January 30, 2019, 10:22:47 PM »
I should have let my 4 legged painter do it  :lolb:
« Reply #557 on: January 31, 2019, 12:29:36 AM »
Watchas use?  his tail?   :lolb:
« Reply #558 on: January 31, 2019, 02:47:20 AM »
Poor Scout, having to climb the ladder to paint the top of that window & door frame no wonder he's all tuckered out. :lolb:
« Reply #559 on: January 31, 2019, 08:47:40 PM »
Uh, that's a bit darker shade of paint than I'd imagined...but then I'm no interior decorator as the missus will attest.
« Reply #560 on: January 31, 2019, 09:27:44 PM »
That's not for the walls bent. It was just a sample on the OSB material. Actually that is the color of the window and door trim.
« Reply #561 on: January 31, 2019, 09:58:43 PM »
Scout wanted to see if we would be able to even get those 4'x8' panels in through the bathroom door and then vertical once in the bathroom. It's tight and I temporarily moved the vanity out of the way, but doable without too much fuss. Got one panel up just to see how it's going to look. The little guy seemed fairly pleased with the results.
« Reply #562 on: January 31, 2019, 10:56:38 PM »
I really like that wall covering. I was just yanking your chain on the painting. When I built my shop, I designated one room for painting. I wanted it brilliant white. The walls were OSB; ‘bout nine gallons of gloss oil base and I had my “brilliant white “ but it still looks like crap if you look at the walls. Let’er age gracefully  :old:  PS: accent at will  8)
Cletus
« Reply #563 on: January 31, 2019, 11:25:22 PM »
A light colored painted wall makes it easier to find the things you throw against it.
Of course, Bill may not have that need...but I do. And it ain't ideas I'm throwing.  ;D
« Reply #564 on: February 01, 2019, 12:16:09 AM »
Zee, my penchant is dropping things on the floor where they are instantly scooped up and whisked away by the shop gremlims never to be seen again.
I hear you Cletus. The OSB painting ain't happening. The throne room is another matter  :lolb:
« Reply #565 on: February 01, 2019, 04:32:26 AM »
I know!
Wall Paper!
 :paranoia:
I'll get my hat....
« Reply #566 on: February 01, 2019, 05:57:08 AM »
I know!
Wall Paper!
 :paranoia:
I'll get my hat....
:lolb: :atcomputer:
« Reply #567 on: February 02, 2019, 03:50:23 PM »
I know!
Wall Paper!
 :paranoia:
I'll get my hat....
I know Pete. If Bill would of just used normal drywall on the walls, I bet he could of found some nice wallpaper that looked just like unpainted OSB!  >:D
« Reply #568 on: February 02, 2019, 04:07:48 PM »
Drywall is fine as long as someone else is hanging it :)  Same for wallpaper!!
« Reply #569 on: February 02, 2019, 07:12:48 PM »
Spray the OSB with white bedliner!
