Author Topic: Zee Needs Popcorn  (Read 59824 times)
Re: Zee Needs Popcorn
« Reply #300 on: August 20, 2018, 04:51:47 PM »
Thanks Dave. Very helpful!
« Reply #301 on: August 21, 2018, 01:59:27 AM »
Nice job Zee, you'll be "teach'in the class" before long !
« Reply #302 on: August 21, 2018, 11:18:26 PM »
Thanks. My 'long' is measured in eons.  ;D Or something a little less.
Did some more work on the crosshead guide. So far...so pretty good.
1st pic shows set up for marking. I don't have a chuck for my spindexer.
So marking went great but then I had to put it in the vise and lost all reference. I used the height gauge and went back and forth from one side to another until I rotate it to 'close enough'.
2nd pic shows the milling out of one side.
3rd pic shows milling the rounded corner. The downside of doing it this way (as I found out) is the metal gets pushed out and over the line I was going for. It was hard to know when to stop. I could have done one of two things. a) Milled from the other side so the cutter goes 'into' the mark. I would have needed a mirror to see that. b) I could have set the mill to just touch and used the DRO. But I'd still have a bunch of metal pushed out that would need filing.
4th pic shows this step done. A little filing and things cleaned up pretty well. I don't know if I reached the target for the rounded corner but it looks pretty close and it won't matter.
You might notice I redid the transition from the smaller outer diameter to the larger outer diameter. It really bugged me but it was pretty easy to correct.
You might also notice a step change, rather than a smooth transition, from the smaller inner diameter to the larger inner diameter. I didn't have an appropriate cutter to do that but more importantly I couldn't see it and didn't want to rely on my measuring. I'm probably going to leave as is but there's a chance I might be able to improve it later.
Whether this goes bad or not...at least I know how to get this far.  ;D
[EDIT] You'll also see the far end's inner diameter looks much smaller. I got there drilling but the boring bar couldn't and didn't need to. All of that gets milled away later.
« Reply #303 on: August 21, 2018, 11:27:11 PM »
Nice stock removal Zee  :ThumbsUp: :DrinkPint:
Eric
« Reply #304 on: August 21, 2018, 11:35:34 PM »
Looking good Zee  :ThumbsUp:
« Reply #305 on: August 22, 2018, 12:00:16 AM »
Nice job!
 :popcorn: :popcorn:    Hmmmm, 'eons'? Better order more popcorn...    :popcorn: :popcorn:
« Reply #306 on: August 22, 2018, 12:41:51 AM »
Nicely done Zee!
« Reply #307 on: August 22, 2018, 12:55:01 AM »
Looking good so far Zee. there are a lot of steps and set-ups in that cross head guide.---Brian
« Reply #308 on: August 22, 2018, 04:28:29 AM »
That looks great, Zee!  :whoohoo:
Offline propforward
  • MN, USA
« Reply #309 on: August 22, 2018, 01:52:44 PM »
This is a fascinating build. Zee - where does one obtain these plans? I'd love to look them over more closely.
Forging ahead regardless.
« Reply #310 on: August 22, 2018, 02:21:22 PM »
Thanks guys!
I'm working off plans from sbwhart. He kindly sent them to me after I PM'd him.
He also wrote an article that's been very helpful.
https://drive.google.com/drive/folders/1Omkz-60W-WmwYr0IBxVTaVOc8tXohgns
Julius also posted a scaled up version in the plans section. (I can't find it off-hand.) It has been useful as well.
Offline propforward
  • MN, USA
« Reply #311 on: August 22, 2018, 02:58:24 PM »
I will search - thank you!
« Reply #312 on: August 22, 2018, 07:19:04 PM »
Sweet. Barely a hint of bitter.
Finished the crosshead guide today. That was quite a bit of fun and I'm pretty happy with it.
I'm not sure of one dimension. Assembly will tell me if I have an interference.
Hopefully that hard transition from the smaller inner diameter to the larger inner diameter won't be a bother.
1st pic shows the other side getting milled out in preparation for rounding the corners.
2nd pic shows the other side's slot done. Used a 5/8 and a 3/4 end mill to do the corners.
3rd pic is basically the same process but used a boring bar to the 1.5" diameter corner I needed.
The last 3 pics are different views of the finished part.
Holding the part for various operations was interesting. Sometimes I packet the sides. For some operations I put a 5/8 boring bar inside so I wouldn't crush the part in the vise.
I used aluminum. If I do this kind of part again then I have a bit more confidence to use steel.
I couldn't have done it without Stewart Hart's article in Model Engineer.
I'll be playing with that part all evening.
« Reply #313 on: August 22, 2018, 07:49:21 PM »
Beautiful looking part Zee. And not an easy part to do by any means. Nicely done!!
« Reply #314 on: August 22, 2018, 08:00:55 PM »
Very nice!!  Quite a complex shape, looks great!
