Author Topic: Double acting Double cylinder Oscillator  (Read 30691 times)
« on: May 24, 2018, 01:52:02 AM »
This is an engine which has always interested me. I think I first seen an engine like this posted by Tel from Australia. I was bored today, so I thought I would begin sussing out a design for one, built from bar stock. The one in this post has 1" bore cylinders with a 1.732" stroke. The flywheel is almost 4" in diameter (I am still trying to find a way to use those two steel rings I made up for the Kerzel. They didn't work out on the Kerzel, but they may do fine here.) Stay tuned, and as the design develops I will posted updated models.
Re: Double acting Double cylinder Oscillator
« Reply #1 on: May 24, 2018, 02:01:20 AM »
Excellent, I love it when you get bored!!
 :popcorn: :popcorn: :popcorn:
« Reply #2 on: May 24, 2018, 03:02:27 AM »
Brian,
Chris is right its time for the :popcorn: as your builds are always entertaining.
« Reply #3 on: May 24, 2018, 04:33:58 PM »
Another 4 hours and we go from concept to an animation of the finished engine. I decided that a 4" flywheel was small enough that it looked out of place, so I bumped it up to 6" diameter.
https://www.youtube.com/watch?v=FUln-ar9By4&feature=youtu.be
[/img]
« Last Edit: May 24, 2018, 04:58:12 PM by Brian Rupnow »
« Reply #4 on: May 24, 2018, 04:45:12 PM »
That would be the "Green Twin" from Preston's as it became known. Tel made a start on his and Pat Jorgenson drew it all out in CAD and made some castings for it. I've still got it on my "future projects" list and if I do make it it will be fabricated but made to look like castings.
« Reply #5 on: May 24, 2018, 04:50:19 PM »
Thanks Jason--I spent about 4 hours cruising the internet looking for that one, but all I could find were pictures of  "Double Tangye" engines.
« Reply #6 on: May 24, 2018, 05:10:23 PM »
 :lolb:
« Reply #7 on: May 24, 2018, 05:23:28 PM »
That's the problem with castings the same old thing crops up again and again, if you want something a bit more original and exclusive you just gota do it yourself.
That little single oscillator I did at Christmas is basically one half you your twin.
« Reply #8 on: May 24, 2018, 06:09:02 PM »
Like a Le Blond 60 engine  ::)
Offline Alyn Foundry
« Reply #9 on: May 24, 2018, 06:15:58 PM »
Le Blonde....
Who mentioned Le Blonde?      :Love:
« Reply #10 on: May 24, 2018, 06:23:34 PM »
I like blondes---
« Reply #11 on: May 24, 2018, 06:34:20 PM »
I love mine!!
« Reply #12 on: May 24, 2018, 06:36:31 PM »
It's got the look of the Morton M5 about it or vice versa :)
« Reply #13 on: May 24, 2018, 06:38:57 PM »
Another nice project Brian. I didn't figure it would be long before something caught your eye. Looking forward to it.
« Reply #14 on: May 24, 2018, 06:55:43 PM »
If I make the spacer transparent, you can see the 1/4" diameter pivot that is attached to the cylinder and passes thru a 1/4" hole in the angle. A stiff little compression spring and a 1/4" nylock nut ensures that the "face" of the cylinder body is held tightly against the face of the angle to avoid pressure loss, but still lets the cylinder pivot.
