Author Topic: Sieg C2 lathe stop starting and unexpectedly reversing  (Read 1202 times)
Offline Richardo
  • Jr. member
« on: May 22, 2018, 03:58:40 PM »
I thought this was a control card problem as my Sieg C2 is 2016 vintage with the brushless motor, no high/low ratio and a complicated motor control card.
Turned out to be a loose connection on the forward/reverse toggle switch. This is this is an input to the control board, not the older multipole cleverly wired switch that reverses the power to the motor on its own. Its a two pole switch. Closed contacts for normal rotation, open for reverse. If you get a loose connection, the lathe will stop then reverse unexpectedly, probably ruining your work piece and tool.
Hope this is helpful to other Sieg C2 users.
Re: Sieg C2 lathe stop starting and unexpectedly reversing
« Reply #1 on: May 23, 2018, 12:37:58 AM »
Hi Ricardo and welcome to the forum. When you have a chance please post an introduction in the introduce yourself section so that all can welcome you properly. Thanks for the tip too. That may help others.
