Author Topic: George britnell straight 6 progress  (Read 5840 times)
Offline rudydubya
  • Western Arkansas USA
Re: George britnell straight 6 progress
« Reply #15 on: May 11, 2018, 06:33:19 AM »
Beautiful work Robbie.  Following along quietly.
Rudy
« Reply #16 on: May 12, 2018, 11:14:35 PM »
I admire anyone taking on a project like this.  Maybe I might someday too, when I get brave enough.  :-\ your work looks great too me.  :ThumbsUp:
Offline wirralcnc
« Reply #17 on: May 30, 2018, 03:53:27 PM »
Made a start on the rods. Machined the big end caps to profile and drilled clearance holes for 2x56 cap screws.
Second photo is the two blanks bolted together ready for machining.
Online Vixen
« Reply #18 on: May 30, 2018, 04:28:25 PM »
That's going to reduce to a nice large pile of chips.
Offline wirralcnc
« Reply #19 on: May 31, 2018, 06:16:51 PM »
Set the blank up and reamed for the big and little ends. Then using a 0.015" slitting disc cut them into individual  rod blanks. Had to use 0.015" as there wasn't much material between each blank.
Next step a simple jig to mount them and machine all over.
« Reply #20 on: May 31, 2018, 08:29:20 PM »
Nice looking operation on the rods. It makes making multiple parts much easier when you can do a lot of the operations and then just cut them off.
Offline wirralcnc
« Reply #21 on: June 01, 2018, 07:09:17 PM »
After making a quick jig. Nothing more than a block with two silversteel pins fitted on the same pitch as the rod blanks. Each blank is held down with 2 brass ba nuts. Rods require machining second side and deburr. But good progress today.
Offline wirralcnc
« Reply #22 on: June 22, 2018, 06:48:52 PM »
Some more progress. Bellhousing set up. A 4" blank 1.25" thick.
All one side milled. Another 2-3 setups to get it finished.
« Reply #23 on: June 22, 2018, 08:57:06 PM »
Nice progress and good to see that you are still posting  :ThumbsUp:
« Reply #24 on: June 22, 2018, 11:16:02 PM »
Robbie,
The six looks great.
Offline michelko
« Reply #25 on: June 23, 2018, 11:24:48 AM »
Hi very nice build. Do you have some Information About the carb? Dimensions?
Thanks in Advance.
Offline AlexS
« Reply #26 on: June 23, 2018, 01:05:17 PM »
Great build so far! Look forward on your building.
Alex
« Last Edit: July 06, 2018, 11:00:06 PM by AlexS »
Offline wirralcnc
« Reply #27 on: July 26, 2018, 10:26:09 PM »
Not had loads of time recently. Work commitments. Family. Annual wkend to Silverstone for the f1.
Have made some progress. Cylinder liners fitted/honed. Crankcase milled requires some blending and holes tapping. Tappet cover machined and timing cover.
Online Vixen
« Reply #28 on: July 26, 2018, 10:33:37 PM »
Very nice workmanship.
I always like that 'machined all over' look.
« Reply #29 on: July 27, 2018, 12:33:27 AM »
I somehow missed this thread completely. Very nice work!  :ThumbsUp:
