Author Topic: George britnell straight 6 progress  (Read 5797 times)
Offline wirralcnc
« on: May 03, 2018, 12:01:35 PM »
Some pictures of progress on the striaght 6. Plans from George britnell.
Rocker box finished.
Sump finished
Cast iron head finished other than cutting valve seats.
Crankcase is about 65-70%.
Re: George britnell straight 6 progress
« Reply #1 on: May 03, 2018, 12:34:22 PM »
That's going to be a good looking engine George.
Were did you source the cast iron head?
Offline wirralcnc
« Reply #2 on: May 03, 2018, 12:57:58 PM »
Hi Mike
I'm Robbie. The engine is from George britnell plans.
The head was machined from solid cast iron round bar. ( just what I had ).
Regards Robbie
« Reply #3 on: May 03, 2018, 01:44:41 PM »
Hi Robbie,
Sorry about the name mix up. Who would ever have guessed the cylinder head was hidden in a piece of round cast iron bar?
« Reply #4 on: May 03, 2018, 04:28:07 PM »
Very nice looking, Robbie!
So, are you doing all the carving by hand? Or are you using CNC of some kind?  If you're doing it by hand, did you get the step-off charts from George, or did you do your own?  Regardless, it is looking amazing!
Offline wirralcnc
« Reply #5 on: May 03, 2018, 04:46:17 PM »
I use manual and cnc. Using featurecam software and an old bridgeport interact. Most of the drilling is done on a manual mill. More feel for the tiny drills.
The cylinder head has alot of detail in and a lot of waste from the big piece of cast iron I had.
Robbie
Offline wirralcnc
« Reply #6 on: May 10, 2018, 08:41:52 PM »
A bit more progress.
Liners machined. Require lapping to size
Offline wirralcnc
« Reply #7 on: May 10, 2018, 08:43:17 PM »
Aluminium rockers with there respective silver steel rollers. Rollers require hardening.
Offline wirralcnc
« Reply #8 on: May 10, 2018, 08:44:48 PM »
Studs that screw in to head to hold the rocker box cover in place. Machined from 303 stainless. 4mm hex bar. 2x56 threads both ends.
« Reply #9 on: May 10, 2018, 08:46:19 PM »
It's great watching another one come to life! Nice work on the rockers.
Offline wirralcnc
« Reply #10 on: May 10, 2018, 08:47:34 PM »
Nuts that screw on to rocker studs. These hold the rockers in place. Again hex bar and 2x56 threads.
Offline wirralcnc
« Reply #11 on: May 10, 2018, 08:52:33 PM »
Cheers George. Its great when I get another part complete. Got material all squared up ready for the conrods and made a start on the valves.
Offline 90LX_Notch
    • YouTube Channel
« Reply #12 on: May 10, 2018, 10:30:20 PM »
Very nice work Robbie.  I'll be following along.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline kuhncw
« Reply #13 on: May 10, 2018, 10:47:12 PM »
Very well done, Robbie.  Thanks for posting your photos.
Chuck
« Reply #14 on: May 11, 2018, 12:57:40 AM »
All the parts so far are looking great, love the rocker arms!!
