Author Topic: Longboy's "INTERNAL BREEZE" Model Engine.  (Read 8430 times)
Offline Perry
Re: Longboy's "INTERNAL BREEZE" Model Engine.
« Reply #30 on: May 22, 2018, 10:33:10 AM »
I'm really looking forward to see this one runing :popcorn:
Offline Longboy
« Reply #31 on: May 22, 2018, 10:18:38 PM »
OK Perry and others!  :Director: Welcome to the mid week presentation of the INTERNAL BREEZE model engine!  :whoohoo:
BREEZE was started on Jan. 9th.
Competed on March 10th.
Some new methods....some new features!  :o
Like a vertical fuel tank.
Cross valve heads.
Forced air cooling via generator & electric fan.
and..... sum strange looking rocker arms! :D  To be continued...........  :cheers:
« Reply #32 on: May 23, 2018, 02:48:57 AM »
Longboy,
I must admit this engine is a mite unconventional, but it looks good and has some great ideas.
Offline Longboy
Re: Longboy's "INTERNAL BREEZE" Presentation.
« Reply #33 on: May 23, 2018, 05:42:20 PM »
Heavy Duty 3 bearing crankshaft, beefy con rods and yesteryear ignition.
OS .10 carb on Delrin manifold. Faux brass mufflers.
The Longboy "INTERNAL BREEZE" model engine.
Let's see it running! :popcorn:
<a href="https://www.youtube.com/watch?v=THl4T9Jt2qw" target="_blank">http://www.youtube.com/watch?v=THl4T9Jt2qw</a>
Thanks for following the story of BREEZE fellow modelers!     :praise2:    See more from Longboy on Youtube, search: "longboy4".    Dave.
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #34 on: May 23, 2018, 08:51:52 PM »
Beautiful engine Dave!  :ThumbsUp: :ThumbsUp: :ThumbsUp:
I like your style.  :popcorn: :popcorn: :popcorn:
Online fumopuc
« Reply #35 on: May 23, 2018, 09:40:47 PM »
Hi Dave, a very nice engine. I do like the open style, so a lot of motion is visible for the observer.
« Last Edit: May 24, 2018, 03:40:01 AM by fumopuc »
« Reply #36 on: May 24, 2018, 12:16:58 AM »
Very interesting engine, Dave.
And it runs well.
You've got to be happy with that!
« Reply #37 on: May 24, 2018, 12:20:56 AM »
Runs great, started up very easily in the video. Very well done!!   :praise2:
« Reply #38 on: May 24, 2018, 12:26:37 AM »
Runs great, starts with the flip of the wrist. Nothing to complain about there.
« Reply #39 on: May 24, 2018, 01:09:32 AM »
Sounds great!
Nicely done.
« Reply #40 on: May 24, 2018, 03:52:15 AM »
As everyone said...it sounds great.  :ThumbsUp: :ThumbsUp:
Very interesting engine.
Any idea how fast/slow it goes?
Offline Longboy
« Reply #41 on: May 24, 2018, 06:29:20 AM »
Thanks Crueby.
What I find in building I/C is that when troubleshooting, when everything is just right they will hand start easily and stay running. Using the drill to start  and the engine runs and stalls/ struggles.......it's telling  you, "not yet, I need more work". Is it fuel mix, valve or spark timing or a tight spot in the reciprocating or rotating assembly? This is a hobby of patiences for sure. :wallbang:   Dave
« Last Edit: May 24, 2018, 07:04:24 AM by Longboy »
Offline Longboy
« Reply #42 on: May 24, 2018, 06:55:06 AM »
Thanks Zeepro...
Using these  model airplane .10-.15  carburetors on my engines, I set for a constant run around 1000-1200RPM idle. They stall out for me when I open the throttle at just a few hundred RPM above idle. I believe this to be the sudden fuel lean out and fixed, no advance ignition timing. Maybe using a R/C buggy carb as their engines respond to on /off throttle input would help......but I would be still short electronic ign advance. Mechanically, they should go a few thousand RPM but being free standing designs, my motors will walk around on the table then!  Happy that they idle smoothly till they run out of fuel.   Dave.
« Last Edit: May 24, 2018, 07:07:07 AM by Longboy »
