Carl, the problem is obvious, you are not doing enough machining!!! When the floor and your shoes are completely embedded with swarf they will become conductive and the problem will go away
I think you need to put one end of a length of chain under the waistband of your tutu and let the other end drag on the ground. Might not solve the static shock problem but the video would instantly go viral and you could make a fortune selling advertising space.
Quote from: mklotz on April 11, 2018, 02:21:18 PMI think you need to put one end of a length of chain under the waistband of your tutu and let the other end drag on the ground. Might not solve the static shock problem but the video would instantly go viral and you could make a fortune selling advertising space.No matter what thread...I cannot escape. Thanks again everyone.I've got a humidity measuring device in the basement. I'll bring it up and see what's what.
