Thanks.I managed to drill the holes in the cylinder mounts. I was pretty careful but both main holes are just slightly off center. Height is right.Not sure what happened.I'm thinking things will be okay though. We'll see once I do more on the cross head.Thanks for the help.
Quote from: zeeprogrammer on April 12, 2018, 08:52:01 PMThanks.I managed to drill the holes in the cylinder mounts. I was pretty careful but both main holes are just slightly off center. Height is right.Not sure what happened.I'm thinking things will be okay though. We'll see once I do more on the cross head.Thanks for the help.What? No Pictures?
Quote from: crueby on April 12, 2018, 09:04:43 PMQuote from: zeeprogrammer on April 12, 2018, 08:52:01 PMThanks.I managed to drill the holes in the cylinder mounts. I was pretty careful but both main holes are just slightly off center. Height is right.Not sure what happened.I'm thinking things will be okay though. We'll see once I do more on the cross head.Thanks for the help.What? No Pictures? You've seen the base. Now it's a base with a couple of non-centered holes. So what's to see?
Worked on the Cross Head Caps. Four of them.I still need to get better at spotting and centering but they should be fine.1st pic is drilling the oil hole and mounting holes. I won't be making oil cups.2nd pic shows the caps installed.3rd pic is the hole that Chris wanted to see.
