Author Topic: PMR #5 - as a fill in project  (Read 14491 times)
Offline J.L.
Re: PMR #5 - as a fill in project
« Reply #150 on: July 14, 2018, 07:15:26 PM »
Hi Bill,
Nice seqquence of operations and photos here.
« Reply #151 on: July 16, 2018, 07:10:40 PM »
Looking good, Bill!
« Reply #152 on: July 16, 2018, 10:13:15 PM »
Thanks John and Bent. I have odeed a 90 degree cutter to cut the "v" grooves n the underside of he valve guide straps, and later in the frame itself. Should have that tomorrow and he same fixture will be used to center the grooves. More on that tomorrow.
« Reply #153 on: July 16, 2018, 10:16:22 PM »
Aren't you able to tilt your mill headstock 45 degrees? That would let you use a normal end mill.
« Reply #154 on: July 16, 2018, 10:22:55 PM »
Yes Chris I could, but am trying to get perfect matching of the v grooves between the straps and frame and I think this way will be easier for that. Good excuse to get a chamfer mill too.
« Reply #155 on: July 16, 2018, 11:14:11 PM »
There ya go.  ;D
« Reply #156 on: July 17, 2018, 12:09:46 AM »
There ya go.  ;D
More tools?   :thinking:
Heck yeah!   :D
« Reply #157 on: July 17, 2018, 12:14:26 AM »
My thinking exactly  :lolb:
« Reply #158 on: July 18, 2018, 09:35:08 PM »
Today the crankshaft got finished. I had turned the two shaft ends previously between centers ( photo 1). In order to turn the crank I had to make a little jig with the proper offset (photo 2) and with that done turning the crank pin wasn't too bad (photo 3). The final part is shown in photo 4.
« Reply #159 on: July 18, 2018, 09:43:02 PM »
That's pretty cool. I don't think I've ever seen a jig like that.  :ThumbsUp:
« Reply #160 on: July 18, 2018, 10:24:31 PM »
Zee, unlike Chuck's procedure using hot rolled steel, this was a CI casting with no "ears" protruding from the crank pin section. My 4jaw chuck is too small to offset the .437" required so this was the only option I could come up with. I'm sure I seen others do something similar. The slot in the jig allows for positive drive and you can see I used a short piece of rod with the center to keep it pressed into that slot. May not be the best way but it worked.
« Reply #161 on: July 18, 2018, 10:31:56 PM »
One of the kits I did many years ago (either a Stuart or a PMR) had this method in the instructions, I still have the big bar I used, makes a good weight. It was just able to fit in the chuck on the Sherline, was a scary operation as I recall, with that heavy a bar out in midair.
 :popcorn: :popcorn: :popcorn:
Online Dave Otto
« Reply #162 on: July 19, 2018, 01:24:03 AM »
Hey Bill
The crank looks great!
« Reply #163 on: July 19, 2018, 11:21:20 AM »
Nice job Bill. I used a jig like that for the Red Wing. They do add an extra bit of rigidity. I just watched a David Richards video and he was working on a full size square valve rod setup like this engine uses. I really like his videos
Cletus
Online steamer
« Reply #164 on: July 19, 2018, 11:59:39 AM »
I like it Bill!    Storing that one away in the file!..
