Author Topic: Bensons Vertical engine  (Read 5129 times)
Offline mikemill
« on: March 25, 2018, 12:40:45 PM »
I recently completed this 1/9 scale Bensons Vertical engine, which is x 1.5 larger than published drawings. Except for the cast flywheel which is from a Stuart Victoria engine all the parts are fabricated or turned from solid bar, the base is aluminium and the column is steel. I could not find commercial helical gears of the right size to drive the governor so had to make them, which proved a lot easier than I had thought, just a case of setting the work at 45deg to the cutter and they meshed nicely.
Of the many peculiar 19th century stationary engines the Bensons engine is a simple yet elegant design, the forked connecting rod dances around the piston rod when in motion. A very enjoyable build.
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: Bensons Vertical engine
« Reply #1 on: March 25, 2018, 01:56:20 PM »
Great looking engine Mike, can we see it running ?
I've always liked the look of the Benson engine and it is on my to do list for when I have the skills to have a go  :)
Offline Mcgyver
  • Toronto
« Reply #2 on: March 25, 2018, 02:20:38 PM »
that looks great - you did a very nice job of it.
What dia. is the flywheel to give a sense of scale?
« Reply #3 on: March 25, 2018, 03:13:15 PM »
Very petty looking engine!  I like the checkerboard tiles you made for the base too!
Offline Jim Nic
  • Buckingham, UK
« Reply #4 on: March 25, 2018, 03:21:08 PM »
Mike - That is indeed a very good looking result.
Mcgyver - the Stuart Victoria flywheel used is 7 inches dia.
« Reply #5 on: March 25, 2018, 04:22:06 PM »
Beautiful engine Mike!
Offline mikemill
« Reply #6 on: March 26, 2018, 09:43:09 AM »
Thanks for all the kind comments.
Kim, the plinth is made from 12mm MDF and the tile floor is self adhesive dolls house flooring found on e-bay.
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #7 on: March 26, 2018, 09:51:18 AM »
Just seen this Mike - must say you have a fine looking model there  :ThumbsUp: A superb result and very eye catching in that green. I agree with you on it's elegant appearance - simple but full of character. I still have a set of enlarged drawings that I did when it first came out - one day eh?
Congratulations on producing such a lovely model
Regards - Tug
Offline scc
  • Lancashire, UK
« Reply #8 on: March 26, 2018, 12:48:59 PM »
NICE :ThumbsUp:   Terry
Offline mikemill
« Reply #9 on: March 26, 2018, 01:20:01 PM »
Hi Tug
Thank you for your comments, I am following your splendid Corliss Tandem engine, also like your tidy workshop, I wish I was as tidy I spend have my life searching for the tool I just put down 60 seconds ago!!!!!
« Reply #10 on: March 26, 2018, 01:43:59 PM »
Mike, same here.   :help:
« Reply #11 on: March 26, 2018, 01:46:46 PM »
Very nice.  There's something really appealing about these open frame vertical engines.  And... I also feel your pain; I too spend half my time looking for a tool I had in my hand a minute ago  :facepalm:
« Reply #12 on: March 26, 2018, 05:49:41 PM »
Absolutely gorgeous Mike. One to be proud of for sure!!!
Offline mikemill
« Reply #13 on: March 31, 2018, 04:13:02 PM »
A short video of the Bensons ticking over as requested
<a href="https://www.youtube.com/watch?v=3_sUrWUdP1Q" target="_blank">http://www.youtube.com/watch?v=3_sUrWUdP1Q</a>
« Last Edit: March 31, 2018, 04:16:04 PM by mikemill »
Offline Gas_mantle
  • North Yorks - UK.
« Reply #14 on: March 31, 2018, 04:21:29 PM »
That's great Mike, an excellent runner and sounds good  :)
I really have to get round to making one of these
