Author Topic: 2.5mm x 30mm hex head bolts  (Read 3399 times)
« on: March 10, 2018, 05:25:37 PM »
As the topic subject implies, I need to find 2.5 x 30mm bolts.  They must be hex head.  I have spent the day searching for them but just can't find them.  Ideally stainless steel but any other material will be good.  As a last resort I may even consider near equivalent in imperial.
Help please.
Offline Firebird
  • East Midlands UK
Re: 2.5mm x 30mm hex head bolts
« Reply #1 on: March 10, 2018, 05:52:42 PM »
Hi Vince
7 BA is a very close size.
Reeves stock them
http://www.ajreeves.com/hexagon-head-boltsscrews.html
Rich
Online Jasonb
« Reply #2 on: March 10, 2018, 06:24:20 PM »
I think you will have a job finding much over 20mm long and they would be fully threaded hex head screws not bolts.
How many do you need? Sometimes for long bolts I thread the end of a rod and silver solder on a nut that way you can make bolts to whatever length you need without having to turn long slender shanks. Or can you use studs and nuts?
« Reply #3 on: March 10, 2018, 07:26:27 PM »
Rich, I checked those 7BA bolts but they are not long enough.
Jason, I can work with fully threaded hex head screws as long as it is 2.5mm thread.
Can anybody tell me what's the closest equivalent in UNF or UNC?
Online Jasonb
« Reply #5 on: March 10, 2018, 08:06:04 PM »
3-48 UNC would be the closest at 2.51mm but #3 is not a preferred size so choice will be limited. Next down is 2-56UNC at 2.18mm.
EKP do 7BA at 1" long which is a bit better than Reeves but still leaves you short.
Longest M2.5 I have are 20mm from GHW.
Online Jasonb
« Reply #6 on: March 10, 2018, 08:11:48 PM »
7BA  x 30 and they are bolts
http://www.ba-bolts.co.uk/smallhex.html
« Reply #7 on: March 10, 2018, 08:52:07 PM »
Those 7BA x 30 look ideal.  Unfortunately they are one size smaller head and I need a regular size head.  Looks like I have to make them myself.
Offline Ian S C
« Reply #8 on: March 11, 2018, 11:05:54 AM »
You could do worse than JasonBs' idea but loctite the nut on with a retaining grade of Loctite, this can be made to look like the head of a bolt, or with a thread showing through, a stud.
Ian S C
Online Jasonb
« Reply #9 on: March 11, 2018, 12:02:00 PM »
I find that if a skim cut is taken after soldering the threaded nut on that the joint shows up far less than if you use loctite.
« Reply #10 on: March 11, 2018, 01:42:20 PM »
I find it very enjoyable making my own fasteners  :) They come in every size you need with the correct head size, chamfered if desired and thread free length :ThumbsUp: And they don't go rusty sitting in the drawer for a couple of decades waiting to be used  ::).
(Cap head screws are another matter  :-\ )
« Reply #11 on: March 12, 2018, 12:39:09 PM »
Something tells me that I will not be enjoying making 120 of them.
« Reply #12 on: March 12, 2018, 02:17:04 PM »
I know the feeling  ::) having to make large batches was why I used to use engineering stud and nut humour to break up the monotony before a bunch of old prudes complained about it  :disappointed:
Offline Allen Smithee
  • Mordor, Middle Earth
« Reply #13 on: March 12, 2018, 08:42:01 PM »
You must be nuts to think that, Jo. Everyone around here knows that your passion for well-formed studs is nothing more than an innocent admiration of skillfully used tools in the pursuit of the perfectly executed screw.
AS
« Reply #14 on: March 12, 2018, 08:43:35 PM »
 :lolb:
