Thank you Chris. I understand.I think if you use a twist drill first, you have to back off early and not let the drill go to its depth - it has an angle on the end that deepens the hole. The whole point of using a milling cutter is to get a flat bottomed hole to an exact depth - if the flutes of the cutter wlll let you go down that far.
